Like Tree134Likes
VBC Lightning FX
Old 06-29-2018, 04:24 PM
  #601
Trader Rating: 78 (100%+)
Originally Posted by ScottZ View Post
i got an fx and i get on the gas out of a corner and the rear end likes to kick out i can't get on the gas out of the corner anybody got a fix for this ?
Start off at the extremes. put 4mm of spacers under the rearward shock end. zero shims under the frontward shock end. Use 300ish oil and the lightest spring you have. Use full droop in the front. loosen the diff to just where it starts to slip. add more pod sag at the pivot point. when it pushes, work your way back until you find the balance you can drive. Good Luck.
Markus is offline
Old 07-08-2018, 04:06 PM
  #602
JeffofSpace's Avatar
Originally Posted by AlexPate View Post
I reccomend this part if you are trying to improve the durability of the upper pins, just make sure you buy the matching c clips
https://gripworksrc.com/products/fla...-b-02-vbc-1005
I know this is a bit dated...but I donít understand where the pin will go?
JeffofSpace is offline
Old 07-08-2018, 04:38 PM
  #603
Fredp1's Avatar
See page 11 of the manual.
Its the upper hinge pin where the upper arms pivot.
Fredp1 is offline
Old 07-08-2018, 08:10 PM
  #604
Old 07-08-2018, 08:19 PM
  #605
Scanned the thread...is there a better option for the kingpin upper ball for the fx? Found one plastic one in one side of my 3rd hand car, and a metal in the other. Which is original? The plastic one is supper tight within the cup, while the metal one is perfect. Any ideas on which metal ball this might be?
Thanks!
Old 07-08-2018, 08:36 PM
  #606
Looked at manual...but what about the little arrma pins?
Old 07-09-2018, 08:59 AM
  #607
AlexPate's Avatar
Trader Rating: 19 (100%+)
They replace the hollow tubes that go through the upper arms.
AlexPate is offline
Old 07-09-2018, 03:17 PM
  #608
Thanks, Alex
but I mean the tiny pins...not the larger hinge pins.
oh, also...I think I have your car...got it from Dave 🙂
Old 07-09-2018, 10:06 PM
  #609
AlexPate's Avatar
Thanks!
No matter what you do for vbc parts there will be slop.
The upper arm set and upper king pin ball from fxm is the best option from vbc. The Yokomo f1 upper ball and ball cup will work as well.
AlexPate is offline
Old 07-11-2018, 08:45 PM
  #610
Old 07-16-2018, 09:06 PM
  #611
FX was excellent last weekend...my first outing with the car. Just sayiní
