SkyRC ARES PRO 13.5 motor
Has anyone tried these?
http://www.amazon.co.uk/SkyRC-Compet...rds=13.5+motor
How do they fair against the bigger brands?
(I don't have to use a BRCA approved motor).
I run these motors exclusively and really like them. I run mostly off road but will be trying one of their 21.5 motors in on road this weekend. I can say I have never been out horse powered, being out driven is completely different for me.
I ran one for awhile had to be geared up big time compared to my Trinity's. It Doesn't spin a lot of RPM but the torque is Huge and it runs cool at tall gearing. I ran it at 3.34:1 in my TC and it came off at 165F.
Thanks for the info
I've been considering this or the Tekin gen 2 13.5 and don't know which to get lol!
Our track is 10m x 15m would you say a torque or RPM based motor would be better for such size track?
I did consider getting the Tekin Gen2 as they offer both RPM and Torque options.
Before the rotor got bend, I used the GEN 1 Type S. It only had 24 degrees timing and although it felt quite fast it didn't feel like it quite had the same amount of power as the others I race against.
High grip small tight tracks you want the strongest rotor available for blinky classes. Boosted works better with a weaker ie broad power band type rotor.
The rotor in this motor would probably suit your track well if running blinky but it might not be legal.
Incase this helps.
The rotor in this motor is a 12.5mm outer diameter and 5mm internal diameter.
Depending on your regs this is not normally legal in spec classes, ROAR ect require the internal diameter to be 7.25mm
Incase this helps.
Incase this helps.
Incase this helps.
Thanks for the info
We can run any 13.5 motor in blinky, or any 17.5 motor in turbo mode.... We do not use and BRCA or ROAR ruling.
So it sounds like the Ares Pro is the one to get as it's half the cost of a Tekin
The Ares pro uses a cooling fan in the rotor too so combined with a fan on the top of the motor I should be able to get some very nice power throughout its powerband
I know I won't be able to race it elsewhere but I only usually race at one club anyway... happy days
I've heard of the Trakstar motors and they hold up pretty well at the club I race at, although I must say the Sky RC sounds tempting to see if they're better, as I would like a little more motor down the straights to outdrag them
The SkyRC is a little more expensive too so I'm hoping it will make it durable
Or do the slower ARES motors not have a fan in them, such as the 13.5?
I have no experience of either motor.
I do agree the torque based motors will be the ticket as you say though Damian, would needs a leaner bottom end with no chance to use top speed on a small track?
