World GT-R Rules and Discussion
#901
Hello all... just introducing myself to you all. Picked up a CRC R/T kit today from Larry's RC and planning on running at either Xtreme Carpet Raceway in Bay City or Hobby Stop West in Toledo.
Picked up a Spektrum Servo, Orion 1S Lipo, and Trinity Certified 1S 17.5 motor.
Now just trying to decide on a 1S ESC. I have never owned a HobbyWing product, was always a LRP guy.
Any feedback/suggestions/comparisons to the different 1S ESCs available?
#903
Add some damper tube lube to the king pins. 50 to 100k as you like. This helps with the chatter. The real issue is a push in the car though. Work on getting that out by making the car a little more aggressive on turning and then dial out the steering with the radio. If you are going to run non glued tires I would recommend O degree reactive blocks in front and raise the roll center a couple of mm. Once you get it right the car will turn on a dime.
#908
So trying to decide on a body for the new ride. I like the Protoform Ford GT and Caddy bodies... kinds torn but leaning toward the GT. I also like the McAllistar Mustang but it is listed as a 190mm body so I am concerned about fitment. I can't seem to find any good pics.... Maybe my google skills need honed.
However, if someone knew where I could get one of the HPI 2000 Trans Am bodies that would be SWEET! I'd have a 1/10th scale to match my full scale!
HPI Racing 7447 Pontiac Firebird Trans Am
Did some searching last night and so far no go...
Chris
Chris
#913
Please understand I am no expert but I was at The Gate Saturday and they were discussing this topic. So I do have first hand knowledge of the pros and cons.
The general idea was/is no glue and make the car less aggressive. Corner speed and lap times should/will improve.
If you have a push with no glue I'll have to let the other guys help with that (for now!). I can tell you they are going to need your setup to help though. Springs (F&R) Droop (Frt & Pod) Kingpin length. Caster, Camber, Toe. Ride Height. Damper tune/ Kingpin lube ETC.
Chris
#914
Chris, at the front of this thread there is a body list. Be sure to check on any body you might consider. I have never seen someone run the TA. At the champs there were a ton of PF Fort GT's. I have tried it but didn't care for it. Heavy and high downforce. It would be my choice on gray carpet though.
On tire gluing. If your track is low to medium grip you won't need it but you do need something on the sidewalls to slide off the boards. I am working on set up with no glue on a medium to medium high bite track (black carpet). I liked it last Saturday but my laps times were not any faster up front. The big difference was the end of the run. On glued tires the car picks up push late in the run. With the non glued tires that didn't happen. It took several adjustments to get the car to not traction roll but once there it was great.
