World GT-R Rules and Discussion >
Like Tree650Likes
Old 11-13-2016, 02:00 PM
  #871
Default Roll out
Roll out for 21.5/ silver can 2 cell. What should I be looking for? Med carpet track what should I start with?60?
Thanks for any info
TeamThibault is offline
Old 12-02-2016, 01:42 PM
  #872
rcguyfpr's Avatar
Trader Rating: 51 (100%+)
Originally Posted by Still Bill
When I decided to convert one of my SE cars over to WGT-R, I called Dumper (Brian Wynn) at CRC.
Dumper said that I had two options:
1) Buy the left and right pod side plates ("tall tire" for the f1 car #3440 & #3442) to convert the back; and, add spacers to the front plate to accommodate the taller tires. Cost: About $40.
2) Add spacers under the left and right pod side plates to convert the back; and, same as above for the front. Cost: Less than $10.
I chose the first option; but, Dumper says the cheaper second option is just as good. Had some old Manutech aluminum spacers to do the front which worked very well.
And, since then, I have also built a new WGT-R/T car too.
Cheers!
Bill
What about converting a LE to WGT-R? Same parts? Any good using a GenX10LE? I am hoping Xray will come out with a rubber version X10 for 2017.
rcguyfpr is offline
Old 12-02-2016, 01:56 PM
  #873
About the only common parts are the front suspension and rear axle/diff.
old_dude is offline
Old 12-03-2016, 03:46 PM
  #874
Trader Rating: 16 (100%+)
You can convert an LE using spacers (option #2 above). Cannot convert with option #1 because it involves too many parts which would not be cost effective.
Bill
Still Bill is offline
Old 12-03-2016, 05:01 PM
  #875
What radio is everyone using it is so confusing
also the esc market is very confusing what is a blinky?
what is everyone running?
wallacefan48 is offline
Old 12-03-2016, 05:22 PM
  #876
howardcano's Avatar
Trader Rating: 37 (100%+)
"Blinky" means an ESC that has no (zero) timing advance. ESCs approved for blinky operation are listed here:
http://www.roarracing.com/approved_non_timing_escs.php
howardcano is offline
Old 12-03-2016, 06:20 PM
  #877
there is a ton to choose from how do you pick?
Old 12-03-2016, 06:26 PM
  #878
is the motor rule going to be changing??
I heard it was a thought of running 13.5
I vote for 21.5 2s
starrx is offline
Old 12-04-2016, 05:25 AM
  #879
Scottrik's Avatar
Trader Rating: 261 (100%+)
I have upgraded to the Spektrum DX6 this fall. Finally gave up on my trusty Airtronics M11 with Spektrum module after 11-12 seasons. I'm happy with the DX6 so far, getting more used to it each time out.
"Blinky" mode is for esc's that are programmable to add timing, etc. "Blinky" is usually called "Sportsman Mode" which does not have alter the timing of the motor, when this mode is selected this is indicated by a flashing light somewhere on the esc or switch.
"Sportsman" esc's are those that do not have programmable timing, true Sportsman esc's, I don't believe, are required to have a blinking light though they certainly can.
I run the Reedy Blackbox 410 esc's in my TC7's for VTA and USGT.
Scott
Scottrik is offline
Old 12-04-2016, 11:45 AM
  #880
is there a specific one for the 1s?
will the stock spec xr10 pro stock spec v4 work with 1s
Old 12-05-2016, 03:38 AM
  #881
howardcano's Avatar
The Hobbywing Xerun XR10 Stock Spec 1S has been recently approved, but I don't see it listed yet on the HW web site. Here is the Pro version:
http://www.hobbywingdirect.com/collections/Xerun-1S-ESC
Old 12-05-2016, 07:02 AM
  #882
i dont see any difference in the v3.1 1s and the 1s
except 50 dollars and 1g of weight
Old 12-05-2016, 09:12 AM
  #883
pphaneuf's Avatar
The v3.1 1S is rated at 120 amp, and the XR10 Stock Spec 1S is rated at 80 amp, I believe? For WGT-R, I expect the lower rating should be completely fine.
pphaneuf is offline
Old 12-06-2016, 08:45 AM
  #884
rmtr's Avatar
Default ? On spacers
Cheers!
Bill
How many mm's were needed to achieve the 5 mm ride height?
rmtr is offline
Old 12-08-2016, 09:31 AM
  #885
dawgmeat's Avatar
Is the Airtronics 94761Z servo good enough for this class
dawgmeat is offline
