World GT-R Rules and Discussion >
Like Tree849Likes
Old 12-11-2015, 04:51 PM
  #361
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by swerv512
Can someone point me in the direction of a reliable booster to run for my LRP flow esc.
i run both of these-
http://www.tqcells.com/TQBOOSTER.htm
or
http://www.hobbyking.com/hobbyking/s...r_for_BEC.html <-- for this one, remove the heat shrink, and replace the three prong plug w/ wire. re-shrink wrap.
hanulec is offline
Old 12-11-2015, 07:21 PM
  #362
swerv512's Avatar
Trader Rating: 21 (100%+)
Maybe a better question is what's the advantage, if any, to running a receiver booster versus a separate receiver pack... I'm thinking of something like a 6.6v 220maH li-fe pack. I appreciate your feedback.
swerv512 is offline
Old 12-11-2015, 07:23 PM
  #363
TOM MAR's Avatar
Page 1 post 1
-Speed Control – Any ROAR approved spec class (blinky) speed control in “blinky” mode. NO RECEIVER PACKS. You may use a specific 1 cell speed control, or a two cell speed control with an external booster. Stock 2 or 4 cap banks that come with the ESC's only. There will be a limit of 10,000 micro farad on cap banks.
TOM MAR is offline
Old 12-11-2015, 08:02 PM
  #364
swerv512's Avatar
Perfect example of why you should start at page one..... Doh!
swerv512 is offline
Old 12-15-2015, 10:05 AM
  #365
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Just released
http://www.teamspeedmerchant.com/sho...l/smr1900.html
This car has been stellar. Great corner speed out of the box.
ammdrew is offline
Old 12-15-2015, 11:45 AM
  #366
Cosmo's Avatar
Originally Posted by ammdrew
Just released
If I can get them to run WGT here that's the car I'm getting. I just switched to a Rev 8 for 1/12 after hearing everyone rave about it. Would like to try it in 1/10 too.
Cosmo is offline
Old 12-15-2015, 12:14 PM
  #367
AMZ
AMZ's Avatar
or
Will those work on a Tekin RS pro ?
AMZ is offline
Old 12-15-2015, 12:39 PM
  #368
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Yes, just use the booster swicth, not the esc switch
RedBullFiXX is offline
Old 12-15-2015, 12:42 PM
  #369
Just throwing it out there for you WGT-R racers
SpeedMerchant are in the game now with a car that is specially designed for the new rubber tire World GT class
WGT4-R
Old 12-15-2015, 12:48 PM
  #370
Yes they work with a Tekin.
I run the HK booster with mine by calibrating the esc with a 2S pack before I install it, then select the 1S check box in the hotwire settings, then tape the power switch somewhere a helpful corner marshal can't get at it and install the booster. No switch, just plug in the battery and drive. The esc gets pretty warm if you turn the switch on.
HW Juststock is exactly the same.
Eddie_E is offline
Old 12-15-2015, 12:56 PM
  #371
I have been running the RCDynamics booster for the past six years and they work flawlessly! Never had one fail. They are tiny. Smaller than a MRT transponder and only weigh 6 grams.
The only downside is they come from England, however shipping is fast and they are a bit expensive. $49.00
http://www.rcdynamics.co.uk/Products.html
Attached Thumbnails World GT-R Rules and Discussion-rcdynamicsbooster00.jpg   World GT-R Rules and Discussion-rcdynamicsbooster01.jpg
Crashby is offline
Old 12-15-2015, 01:22 PM
  #372
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Just released
Bruce said you lapped the field.
liljohn1064 is offline
Old 12-15-2015, 02:47 PM
  #373
If I'm not mistaken,didn't a stock CRC SE win the Cleveland race?
BullFrog is offline
Old 12-15-2015, 03:05 PM
  #374
As for an cheap and works VERY well ESC with No booster try a Hobby Wing - Just Stock or JR10. I know they say two cell but you can run them without a booster. We have been running them for awhile both in road course and Oval(with NO booster).If you want a booster Hobby Wing has one also.
BullFrog is offline
Old 12-15-2015, 03:50 PM
  #375
ammdrew's Avatar
Last weekend yes, Car was exceptionally good. just carried so much corner speed that the fade was so much less through the run.
ammdrew is offline
