World GT-R Rules and Discussion >
Like Tree810Likes
Old 10-18-2023, 05:25 PM
  #2521
Originally Posted by Zerodefect
You stand over the car, look straight down. See tire = fail.
It's almost as if you didn't read any of my post that you replied to.
MC Hamilton is offline
Old 10-18-2023, 05:27 PM
  #2522
Don't know whut ya'll talking about. Akura fits perfect.
How wide is your rear track? Looks pretty narrow.
Old 10-18-2023, 07:26 PM
  #2523
Zerodefect's Avatar
I was simply explaining how that rule works in nearly all motorsports. Look straight down, no tire. It's the top of the fender only.
If the car is actually fast, having a tire peeking out, royally sucks for your aero. So its a self solving issue, mostly.
Track is, as per manuals shims. Wide shim on one side. 3 thin on other. As narrow as anyone I know.
Zerodefect is offline
Old 10-19-2023, 06:15 AM
  #2524
Billy Kelly's Avatar
I tried. Left mine 2 weeks ago with one of the usual top 3 drivers at the track. He made number of changes and was able match times with his. Unfortunately it’s just the same back on my controller. Can not make this car steer.
first few minutes are WGTR
https://youtu.be/H0y-zqKrAD8?si=uO2aBfwfBJTbJu8L
Billy Kelly is offline
Old 10-19-2023, 08:36 AM
  #2525
Zerodefect's Avatar
I didn't see it get up on 2 wheels, or traction wobble. If the car ain't trying to flip somewhere, it ain't the cars fault.
Not enough dope?
Old 10-19-2023, 08:59 AM
  #2526
Not enough dope?
I donít have enough travel on the controller to make it turn.
Tired full tire with sauce.
full rear, inner front
then zero sauce for why not.
ran basically same. It canít turn.
Old 10-19-2023, 09:20 AM
  #2527
simple's Avatar
Define "controller" - are you referring to your transmitter?
Which one do you have?
Possibly a setting with endpoints or dual rate on the servo channel?
simple is offline
Old 10-19-2023, 11:41 AM
  #2528
I think he is just saying that even at full lock, his car won't turn in enough.
Old 10-19-2023, 11:58 AM
  #2529
Futaba 4pls. Canít turn the controller wheel far enuff to turn. Left or right. Iím used to driving not properly setup cars/buggies. But even those I can find a way to drive them.
Old 10-19-2023, 12:05 PM
  #2530
Zerodefect's Avatar
Sounds like endpoints need adjustment. Along with some steering work on the car.
I glued the servo saver. Added caster. Raised the upper arm. Full small. Loose diff. High rear ride ht. Small spur, motor back.
I could put in an Xray servo saver, but those are so stiff, a glued saver on this little servo is no worse.
simple likes this.
Old 10-19-2023, 12:38 PM
  #2531
I’ll get back to it in few weeks. Since it’s still not right just make weekend decisions simpler.
simple likes this.
Old 10-20-2023, 06:07 AM
  #2532
Raising the upper front arms reduces steering. That is lowering the roll center. You do that is the car has too mush steering or it is lifting.
old_dude is offline
Old 10-20-2023, 08:11 AM
  #2533
Zerodefect's Avatar
Exactly. It'll help plant the car to the track. My caster is maxed out to make up for it. Little extra front dope thanks to the roll center.
Touch of toe in to dull entry, and help middle.
Old 11-30-2023, 07:03 PM
  #2534
Default Front droop adjustment
I have a gen x10 rt and wondered how front droop is adjusted. The manual says to just allow springs to touch no gap or preload.
Ice45man is offline
Old 12-01-2023, 10:17 AM
  #2535
Trader Rating: 47 (100%+)
Loosen little brass set screw and screw king pin in to reduce droop or unscrew king pin to increase droop. Don't forget to retighten little brass set screw.
biz77 is offline
