World GT-R Rules and Discussion >
Like Tree810Likes
Old 07-18-2023, 06:00 AM
  #2476
R/C Tech Elite Member
mrreet2001's Avatar
Originally Posted by Billy Kelly
Iíve done enuff of these trophy races for off road to know thereís no time to really fix something. Hopefully Wednesday Iíll get some. Only 3rd race with this car. I was hoping to at least have better idea on how the spec Gravity motor we run compared to open motor. Iím only 1 lap down at ThunderDome. I gotta check what we are running for the Trinity race.
"MC" is a machine. I am pretty sure he had his 12th scale car 80% apart at one point last weekend.
MC Hamilton likes this.
mrreet2001 is offline
Old 07-18-2023, 10:15 PM
  #2477
Sadly, all that work, changing something every round and changing big stuff in the final round, only got me 0.02 seconds a lap for each try. So only got 0.06 seconds faster from start of day to the end. My car was pretty quick to start with, but Greg had 0.2 on us so I had to try whatever I could. I certainly did not get most improved for the day. Thinking that you might have?
GregAnthony likes this.
MC Hamilton is offline
Old 07-19-2023, 06:05 AM
  #2478
mrreet2001's Avatar
My fast lap really didn't change a whole lot. I was around 9.4 all day.
MC Hamilton and GregAnthony like this.
Old 07-19-2023, 06:15 AM
  #2479
Billy Kelly's Avatar
I never got passed a 10.3
Billy Kelly is offline
Old 07-19-2023, 04:07 PM
  #2480
what were you geared at?
GregAnthony is offline
Old 07-19-2023, 04:15 PM
  #2481
stock spur. 40t for r1. Then went to 35t. Also running the spec gravity motor that ThunderDome requires. I donít think the motor was as big an issue as Iíd like it to be. Itís probably more in how inconsistent the steering has been. Especially on a smaller, tighter turn track
Iíve never been good at gearing. And over here most guard their gearing setting like itís gold.
Old 07-24-2023, 09:09 AM
  #2482
https://youtu.be/G9JNJVNH5RQ
TOM MAR likes this.
Old 07-24-2023, 09:57 AM
  #2483
Xpress's Avatar
We run spec motors....it's not complicated:
Run the car - how bad does the car fall off over a run?
Add a tooth - do you go faster? Does the car fall off worse over the run?
- if you go faster with the same fall off...add another tooth
-if you go same speed with more fall off work the other way and take a tooth off
Xpress is offline
Old 07-24-2023, 10:15 AM
  #2484
Unfortunately, nothing with on road has been that simple for me. Most days with GT12 I can run 6-7 different pinions with no difference.
Iím still trying with WGTR. Gearing isnít my biggest problem with WGTR. At least not on the bigger track
glennhl likes this.
Old 08-07-2023, 01:56 PM
  #2485
From the weekends Trinity race at ThunderDome. Didn’t make it out of the B. I’m still struggling with getting mine to turn.
https://youtu.be/MZcgcbVYNtw
Old 08-07-2023, 02:28 PM
  #2486
Trader Rating: 88 (100%+)
From the weekends Trinity race at ThunderDome. Didnít make it out of the B. Iím still struggling with getting mine to turn.
What chassis are you running?
MUDVAYNE is offline
Old 08-07-2023, 02:51 PM
  #2487
CRC. Same as most local running it. Iím thinking now itís more me than car. Canít get a feel for how to get it to turn. Doesnít drive like a 1/or a touring car. On paper thereís basically 1 second 1-to last. First ran 11.8/12.1 average. I ran 12.713.2 average. That works out to 2 laps down
Old 08-07-2023, 05:36 PM
  #2488
no tamiya bodies?
Meji is offline
Old 08-08-2023, 05:19 AM
  #2489
CRC. Same as most local running it. I’m thinking now it’s more me than car. Can’t get a feel for how to get it to turn. Doesn’t drive like a 1/or a touring car. On paper there’s basically 1 second 1-to last. First ran 11.8/12.1 average. I ran 12.713.2 average. That works out to 2 laps down
Check the mounting bolts that hold the suspension to the butterfly plate. If those bolts pass through the lower arm and you have a minimal amount of shims it could be rubbing against the upper arm, which make the suspension not want to work properly. Also make sure you don't have a bent kingpin or kingpins. if they are bent the car won't want to turn either.
Also check the amount of glue on the front tire. If there's too much and it's over the top of the contact patch of the tire then it will not turn as well.
MUDVAYNE is offline
Old 08-08-2023, 05:34 AM
  #2490
If all of the suspension is in good and free working order I recommend playing with battery position in that car. I run the latest version and there are a ton of options. Don't follow the pack, try something different. My CRC has the battery forward and inline. That makes the car drive well with a spool. If I want more steering I move the battery back. More yet, full rear. It can also be turned sideways with multiple positions. On our black carpet the front is .45 to .50 springs, 5 deg reactive with caster to fine tune. Rear is .45 side springs, 20k in the tubes. Center is red or stiffer w 35w. Roll center is 2mm under the mounts. Our track is newer CRC black (put down in Feb.
Hope some of that helps.
old_dude is offline
