World GT-R Rules and Discussion >
Like Tree849Likes
Old 02-14-2023, 06:02 AM
  #2416
trackdesigner71's Avatar
Outstanding that you guys have been able to a) find a new facility b) keep a legendary group alive
trackdesigner71 is offline
Old 02-15-2023, 03:56 AM
  #2417
That is very true and all the hard work has produced what I think may be one of the nicest racing facilities around.
davidl likes this.
old_dude is offline
Old 02-20-2023, 08:27 PM
  #2418
Trader Rating: 71 (100%+)
Ran my first practice session with my new X-ray x10. Car worked good, turned in greatÖlittle to good at times. High speed sweeper into 180 wanted to traction roll high speed sweeper it was lifting inside front tire.. Iíve got standard kit setup, with links pointed in, shock spaced up 2mm in rear, side springs at 2mm running center spring at 2mm and gold spring. New tires, no glue yet on fronts, I raced crc until I got this car. Crc worked pretty good, Iím not dead set on keeping the X-ray yet, but Iíve only had it one practice day
Sortafast likes this.
rcracersb is offline
Old 02-21-2023, 04:54 AM
  #2419
I just started running the new CRC WGTR car last Wednesday. Outstanding right out of the box with a complete kit setup minus the diff (started with a spool) and with the optional side rails.. Really impressed.
anythinggas and AsphaltFlyer like this.
old_dude is offline
Old 02-21-2023, 10:51 AM
  #2420
Sortafast's Avatar
probably worth trying a little glue.
or less camber
mrreet2001 and AsphaltFlyer like this.
Sortafast is offline
Old 02-22-2023, 09:12 AM
  #2421
Big Jeff BBQ's Avatar
On the CRC what gearing are you using ?
I just got a CRC and trying to figure out the gearing.
Big Jeff BBQ is offline
Old 02-22-2023, 09:21 AM
  #2422
Smaller tracks 33 to 35 / 92. Larger tracks can sometimes handle 36-37 pinions.
MC Hamilton is offline
Old 02-24-2023, 04:09 AM
  #2423
Need to know the motor for gearing but that is a ball park. With the out of the box (timing is really close to spot on) Hobbywing G4R i am running 40/96 on our track. 88 x 36. The HW is a torque motor as it sits so a little taller gear. A HW G3R would be a little lower in gearing as it is more of a RPM motor. Just examples of how it can change for a motor/timing setup.
old_dude is offline
Old 02-24-2023, 08:49 AM
  #2424
YBSLOW's Avatar
What body are you running?
YBSLOW is offline
Old 02-24-2023, 07:59 PM
  #2425
Insane's Avatar
What timing are you running on your Hobbywing?
Insane is offline
Old 02-27-2023, 04:21 AM
  #2426
Right around 38, just like it came out of the box. I worked with it on the Fantom Dyno up and down, Ended up right back at 38. Going higher hurts the bottom end and hurts efficiency.
Insane likes this.
old_dude is offline
Old 02-27-2023, 04:22 AM
  #2427
If the question is for me, I run The Akura.
old_dude is offline
Old 03-01-2023, 01:56 PM
  #2428
The body list has been updated to add the Bitty Designs AR8-GT3
dumper is offline
Old 03-02-2023, 04:25 AM
  #2429
Good choice. I saw won this weekend and it is very true to the GT3 car.
Now please use your influence to get a Mustang GT3 car from Protoform. It would look great in pink.
LonnyJ1950 likes this.
old_dude is offline
Old 03-02-2023, 04:51 AM
  #2430
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
I have note run wgtr yet so I am unsure about some of details. Are you guys running 200mm or 190mm? It looks like some of the approved bodies are 190mm.
I understand rules state up to 200mm but are you finding 190mm bodies are better option?
J.Gonzalez is offline
