World GT-R Rules and Discussion >
Like Tree823Likes
Old 01-15-2023, 04:13 PM
  #2386
anythinggas's Avatar
Trader Rating: 21 (100%+)
need a little help
just picked-up the new model CRC WGTR. but having a issue, the car wants to roll over and it seems like it's traction rolling. the car just fills like it's very agressive to point i can't even run full speed through a sweeper., just need some more suggestions to help settle it down.
anythinggas is offline
Old 01-16-2023, 09:00 AM
  #2387
Trader Rating: 40 (100%+)
Originally Posted by anythinggas
need a little help
First thing is to use super glue and coat the outside of the tire. I start at the edge of the contact patch where there is a step up edge. I go all the way down to the bottom of the CRC label on the sidewall. There are plenty of YouTube videos available for doing this. May not be the same tire, but the process works on all tires. Second is to use 30K lube in the damper tubes that run side to side at the rear of the car. Next is to use 2 caster shims forward on the front caster blocks. Give that a try and report back.
AsphaltFlyer likes this.
davidl is offline
Old 01-18-2023, 07:01 PM
  #2388
need a little help
Which body are you running? I have tested many and the body makes a huge difference in this class.
MC Hamilton is offline
Old 01-19-2023, 06:17 PM
  #2389
running the Zoodiac GT
Old 01-19-2023, 07:24 PM
  #2390
That's the fast one. I had a friend take some slow motion video on his iphone of my car going through the corners where I was traction rolling. We could then see which inside wheel was lifting first. I doing this, we spotted two conditions. One, the inside front wheel lifting first, then the rest of the car following into the flip. We were able to fix the traction roll issue (already had front sidewalls glued) by running stiffer side springs at the rear of the car and heavier damper fluid in the tubes. The video showed the car sort of dumping over to the outside rear. Two, the inside rear lifting first or both lifting together. To reduce traction roll for this condition, we went with softer front springs and increased roll center on the front, trying to allow the front end to dive more on the outside front wheel. Just sharing what worked for us. You'll have to test on your own. I run a Roche, not a CRC so results may vary.
Old 01-20-2023, 04:58 AM
  #2391
On the CRC I lower the roll center (raising the upper arm) to reduce TR. Last step is the long arm option for really high bite. The CRC front end has shorter arms than most to start with. The long arm is close to a Associated style, maybe just a mm longer.
old_dude is offline
Old 01-24-2023, 04:44 PM
  #2392
Always liked this class, with the New CTC coming out, I got one, ran at BG this week end, might be my new favorite class, even more so than GT12! Had a highly competitive group at BG.
Can't wait to run against David again soon, and if Hammie ever runs again too.
There is a group that started to run ay Larry's on Fridays, and only once a month at RC ONE (both in Michigan).
mrreet2001 likes this.
GregAnthony is offline
Old 01-24-2023, 06:04 PM
  #2393
Making a comeback this Sunday. Haven't raced since last April. Did a practice day at Larry's a few weeks ago and the cars all still worked. What are we running in Bowling Green? WGTR and GT12? I want to race 17.5 1/12th but I hear that died in BG.
Old 01-26-2023, 05:46 AM
  #2394
R/C Tech Elite Member
mrreet2001's Avatar
WGTR and GT12 are the only pan car classes we currently run. Every so often we will have enough to run 17.5. It's one of those luck of the draw things as to whether the few that want to run it all show up on the same day.
mrreet2001 is offline
Old 01-26-2023, 07:01 AM
  #2395
need a little help
Brian Wynn did a seminar at our race last week and he discussed his method of gluing the tires. The raw footage will be posted soon on the Queen City Rc facebook site. I think that will help.
Rick Vessell and GregAnthony like this.
dyoung is offline
Old 01-26-2023, 11:17 AM
  #2396
I always liked "raw footage."
davidl is offline
Old 01-26-2023, 02:43 PM
  #2397
We will be prepared to race GT12 and WGTR, depending on the 2-4" of snow in the forecast.
I will bring my 17.5 1/12th and maybe I can convince David Lee to jump out there for a practice run or two?
Old 01-27-2023, 12:18 PM
  #2398
trackdesigner71's Avatar
Chevrolet just unveiled their 2024 GT3 challenger, the Z06 GT3, would love to see someone try something similar for WGTR
trackdesigner71 is offline
Old 01-28-2023, 04:02 AM
  #2399
Protoform does the C8 but it does not handle as well as several other bodies.
old_dude is offline
Old 01-30-2023, 09:21 AM
  #2400
mrreet2001's Avatar
The PF C8 does well in Bowling Green Ohio. I couldn't keep the zodiac off it's roof.
