World GT-R Rules and Discussion >
Like Tree849Likes
Old 12-27-2022, 07:15 AM
  #2371
Originally Posted by AsphaltFlyer
The kit setup is very good for black carpet. Also the kit instructions break down what each change does for driving characteristic. The only part change I've made is removing the side rails for more corner speed and adding the -4mm front plate from side piece racing. It's the most dialed, easy to drive & easy to tune.
ive never heard of this piece? Is there a part number or description somewhere about it? Had Roche WGTR for years and didn't know anyone made any option parts..
dyoung is offline
Old 12-27-2022, 09:08 AM
  #2372
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Synergy Racing Products Roche Rapide P10 WGT-R CF Front Suspension Plate - 4mm
you can also buy directly from Synergy Racing Products
hanulec is offline
Old 12-27-2022, 09:23 AM
  #2373
anythinggas's Avatar
Trader Rating: 21 (100%+)
How would this benefit the set-up of the car on a medium size track with medium traction
anythinggas is offline
Old 12-27-2022, 08:05 PM
  #2374
hanulec's Avatar
shorter wheelbase. more rotation.
hanulec is offline
Old 01-08-2023, 09:31 PM
  #2375
Trader Rating: 41 (98%+)
New tires sure make the car faster. Same as 1/1 scale.
davidl is offline
Old 01-09-2023, 04:25 AM
  #2376
The newer tires (almost 2 years ) are faster but mine and several others have noticed a weird wear pattern and it happens fairly quick. The tire will show a depression about 1/4 inch in from the outside. Just something we have seen.
old_dude is offline
Old 01-09-2023, 08:34 AM
  #2377
Front, rear or both? Is this the infamous "death ring"?
davidl is offline
Old 01-09-2023, 10:50 AM
  #2378
Any truth to the new tires being a softer rubber?
MC Hamilton is offline
Old 01-09-2023, 11:09 AM
  #2379
This has been discussed on & off for the past season or so. High wear rate and graining. I asked Dumper about it at Mile High Indoor Champs and I was told they had no knowledge of this and they had still been running the same set for a couple years now. Makes it even worse when they are close to $80/set and front or rear isnt available separate.
AsphaltFlyer is offline
Old 01-10-2023, 04:57 AM
  #2380
Not in the same location and much different in appearance. Ring of death was inside edge and close to the shoulder, This is outside edge and in further. You can run the tires a long time with it but it is the eventual end of the tires life. It will start the first race weekend on the fronts first.
davidl likes this.
old_dude is offline
Old 01-10-2023, 10:57 PM
  #2381
hate to say it as I love this class but it's dying in the midwest and northwest because of the tires. In fact lots of people are preparing for the switch 'back' to foams. would be nice to see some other players in the tire game
Old 01-11-2023, 04:58 AM
  #2382
That would be sad to see. I came from WGT which was the foam class. I can tell you though even at $80 a set, it is still cheaper to run the rubber. To run at the top level you will use several sets of foams at a major like the indoor Champs. Just look at 1/12 scale for that. 4 sets for racing and 3+ for practice. That is fairly typical for the "A" and probably "B" groups. Going back to foams will cause that same push.
davidl likes this.
old_dude is offline
Old 01-11-2023, 05:11 AM
  #2383
simple's Avatar
Class is growing for us in the NorthEast. Guys that have never driven 1/12th scale are joining in, which was the goal in the first place. If it fizzles out elsewhere, that good for us because it will be easier to get inventory.
Rubber tires that exibit some unsual wear, still seems to take longer to happen, has less of an effect on performance, and is easier to address - than a chunked or ripped foam tire.
simple is offline
Old 01-11-2023, 10:13 AM
  #2384
^ both very good points. I think the shift was sometime last year when the CRC tires would only last maybe a couple of club races and the performance would drop off. I'm talking a new set/month. The last set our crew has been on has lasted longer. I'm on club race #6 with this set with consistent performance.
Old 01-11-2023, 12:37 PM
  #2385
mrreet2001's Avatar
It one of our largest classes @ Black Swamp RC Raceway in Bowling Green Ohio.
davidl likes this.
mrreet2001 is offline
