World GT-R Rules and Discussion
#2297
Hey Keith. Our season is supposed to end Nov 30. There are some drivers that want to extend into April since there isn't any outdoor season this year. A decision on the actual closing date for the indoor track will be made in the next week or two. I have no clue which way this will go.
#2298
#2301
The Body list has been updated, listing the Bitty Designs Ahura.
Also, the rule regarding the tires sticking out of the bodies, has been amended. Tires can now stick outside of the bodies as long the over all width of the car is within the 200mm maximum.
#2302
Hi all, my firend's X10 22 is having issues flippin on it's side when entering curves. It is setup for WGTR class. The setup is pretty basic except for extra shims to get the ride height high enough for this class (5.2 mm). His pod shock has a 3dot black spring and the rest is as per kit.
Now, I have basically the same setup and not experiencing the car flipping over on it's side. I am running a Tekin 17.5 and he is running a Sonic 13.5 motor. The rest is the same except that his car is 17 grams lighter than mine.
We are scratching our heads and need some input on whta we can try to solve the problem before our Sunday race.
#2303
Hi
You can try to widden the rear with shims , and soften the lateral dampers (grease and springs)
it will gives the car more roll in the entry and counter the flip effect
if this doesn't work you can apply some CA on the front tires , only on the wall (side)
#2305
#2306
Other things to try:
Soften the springs and damping to let the chassis roll a bit
Increase front droop to 1mm or more
Glue more of the front tire sidewall, but be careful - once you've added too much, you're kinda stuck. I suggest having a couple sets of fronts, one glued to cover the CRC label and one that goes to the line near the top of the tire.
I also noticed that having changed to a spool, the car wants to traction roll more than with a diff. If your car is really bad at flipping, maybe run a diff?
#2307
Which body are you running? The body makes a HUGE difference. Most of them that are under 95 grams work. Any of the heavier ones put a lot of weight up in the canopy of the body and roll more.
Thanks for the help.
#2308
World GTR
I have an old 3Rscing f109. I have put a F203gt front bumper on it and made carbon mounts for the rear. I woyld like to install a World GT body. The car measures out to 200mm but the wheelbase is 268mm. Will most WGT bodies accept this wheelbase or do I have to get "creative" with the wheel arches? I do not plan to race; just outdoor basketball and tennis court running.
#2309
Associated 10R5.1
Working on a chassis for this class, with a budget in mind, what would be the top 3 single cell lipos?
