World GT-R Rules and Discussion >
Like Tree849Likes
Old 11-02-2021, 01:33 PM
  #2221
ShtLuck's Avatar
Trader Rating: 45 (100%+)
can we add this to list... https://mcallisterracing.com/shop/ol...ot-rod-gt-body
asking for a friend. lol
ShtLuck is offline
Old 11-03-2021, 04:43 AM
  #2222
I am sure no. Dumper actually ran that body in USGT for a bit so he is vey aware of it.
old_dude is offline
Old 11-03-2021, 10:08 AM
  #2223
sduffy77's Avatar
Trader Rating: 24 (100%+)
That is badass! It's race directors discretion right? lol
sduffy77 is offline
Old 11-03-2021, 02:29 PM
  #2224
Not to throw shade but if a club wants to race off the books bodies go for it. But if racers want to go to events away from the local track they should just be aware of the rules that they will need to follow. We get that occasionally at our track as we run by the rule sets in all classes. Leniency is shown to newcomers but they get advised of the rules in a friendly way.
On our walls are posted a spread sheet with basics and notes to specific locations for details.
mrreet2001 and TOM MAR like this.
old_dude is offline
Old 11-10-2021, 10:49 AM
  #2225
Trader Rating: 42 (98%+)
Originally Posted by old_dude
There are a couple of thigs that can be done. A machinist friend of mine modified the rear slider to move the bearing on the diff side inward a couple of mm. I also had a couple of old rear axles that do not have a hub on the backside of the diff ring plate. A spool is easy so no explanation needed there.
One thing anyone can do is make a spacer out of 1/4" I.D. tubing and put the flange of the rear bearings on the inside of the bulkheads with the tubing between them to transfer loads. For a X-Ray gear diff there may be a new aftermarket hub in the future that moves the wheel inward. I am testing that now and could easily take the car into the low 180's with that. I will tell you that less than 188 isn't recommended.
I have let Dumper at CRC know that moving the bearings inward benefits the handling and made a suggestion to them for a small design change in the sliders. We will see.
I heard about moving the bearing. I have moved the right side hub closer to the gear and the diff flange closer to the bearing, but still using the 2mm wide spacer. My rear width is less that 187mm. So how narrow did he end up making the rear of the car? By the way, did you know that is my original Gen10 R/T?
davidl is offline
Old 11-10-2021, 11:31 AM
  #2226
I run it between 188 and 194 depending!! Like I said I can go less with the gear diff or spool but handling starts to get shakey.
My car is the Gen-X R/T but here is one better. We have a oval class that requires a WGT chassis and McCallister Indy body. I use the original Gen-X for that class. I bought that kit on my return from a house building hiatus in 2008. That is still a competitive car and still available from CRC.
I am guessing that we will see a new kit soon. The adjustable rear roll center from the new 1/12 scale kit will make its way there. Probably into the F1 also.
davidl and MarkBurgess like this.
old_dude is offline
Old 11-23-2021, 09:41 PM
  #2227
New center pivot conversion kits now available from CRC for the GEN X 10R/T.
davidl is offline
Old 11-23-2021, 09:59 PM
  #2228
Trader Rating: 25 (100%+)
I looked for it, but I could not find it on the crc website.
photeckk is offline
Old 11-24-2021, 04:37 AM
  #2229
To new. Frank is bringing them to the Indoor Champs.
old_dude is offline
Old 11-24-2021, 08:46 AM
  #2230
Rockin Rich's Avatar
Go to their Facebook Page
Rockin Rich is offline
Old 11-24-2021, 05:14 PM
  #2231
Use p/n 18661 in the search bar.
photeckk likes this.
davidl is offline
Old 11-24-2021, 05:15 PM
  #2232
The center pivot conversion also fits the current F1 car.
davidl is offline
Old 11-24-2021, 07:09 PM
  #2233
trackdesigner71's Avatar
Looks like 1S 17.5 Handout for the Indoor Champs
trackdesigner71 is offline
Old 11-27-2021, 04:37 PM
  #2234
Same Hobbywing motor that they used 2 years ago. Not a bad motor when geared right.
old_dude is offline
Old 11-28-2021, 10:00 AM
  #2235
What is the benefit of the new part/design? I see other manufacturer are using similar setup.
AsphaltFlyer is offline
