Ceramic Bearings
Old 08-21-2015, 05:16 PM
nogarats's Avatar
Default Ceramic Bearings
Is it worth it to use ceramic bearing throughout the car or is it a useless expense?
Thanks in advance,
Nog.
nogarats is offline
Old 08-21-2015, 05:22 PM
Trader Rating: 23 (100%+)
in terms of maintenance, ceramics won't wear as quick as steel bearings but they will still require cleaning and oiling. Better to just replace steels more often (you could probably get 5 steel bearings for a ceramic).
but they will offer a slight performance advantage, that probably won't be useful unless you're the most consistent driver at your race
Zhangesh is offline
Old 08-21-2015, 05:54 PM
nogarats's Avatar
Thanks Zhangesh
nogarats is offline
Old 08-21-2015, 06:01 PM
Quite a lot of discussion in this previous thread here:
http://www.rctech.net/forum/electric...-bearings.html
cplus is offline
Old 08-22-2015, 06:01 PM
nogarats's Avatar
Thanks for the link
nogarats is offline
Old 08-23-2015, 02:48 AM
Roelof's Avatar
Originally Posted by nogarats View Post
Thanks for the link
You would be amaze with what you can read with this link:
http://www.rctech.net/forum/search.php
Roelof is offline
