Old 10-31-2005, 04:17 AM   #1
Superdate's Avatar
Default About Zero-V discharger
Just want to find out my friends, how often do you use Zero-V discharger or similar discharger to recondition your battery?
Superdate is offline   Reply With Quote
Old 10-31-2005, 04:37 AM   #2
I use the Novak Flatliner trays... Usually after every run,I'll dump off my cells using my spintec and then I'll tray them.
Ben.C is offline   Reply With Quote
Old 10-31-2005, 04:56 AM   #3
Superdate's Avatar
then you will have at less 2-3 of the trays? cos each time it takes 3 days to recondition the battery on Zero-V discharger.
Old 10-31-2005, 05:04 AM   #4
Paladin's Avatar
Discharge batteries with CDC V6 or Much More CTX, then I use my Integy 6s trays for 24 hours each battery. Then store till next meet.
The Integy 6s are the same design as the Much More Zero V and are about $20-00 cheaper!
Paladin is offline   Reply With Quote
Old 10-31-2005, 08:32 AM   #5
Alex_kipper's Avatar
There is No need to put your battieries on the Zero-v for 3 days, the longest i have ever put them on is 2 hours.
Before a charger(25min before) put the batteries on the tray, and then right before the charge, toss them on the charger, and there ready to go.
Alex_kipper is offline   Reply With Quote
Old 11-01-2005, 02:11 AM   #6
jas
jas's Avatar
Do you need to unscrew the contact to the cell as soon as the light bulb goes out on that cell? Or just wait until all the light bulbs go out? I want all the cells to be as equalized as possible.
Thanks!
jas is offline   Reply With Quote
Old 11-02-2005, 11:16 AM   #7
is there a big difference between the zero equalizer and the zero 6? And do most people run a few trays.
This is a good topic for newbs as my endless searching has me more confused than ever before.
6g72tt is offline   Reply With Quote
Old 11-02-2005, 04:09 PM   #8
Nexus Racing's Avatar
The MuchMore Zero-V and Integy Zero-6 do look identical, but they are a little different. All of the contact posts on the MuchMore unit go through the top deck and connect to the bottom deck, while the ones on the Integy unit only do this for the end cells (1 and 6). As a result, the Integy Zero-6 will flex some when you tighten the posts.
There are no functional differences between the two trays, though.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
what's the diff btwn 0-30 discharger & novak smart discharger straightaway Electric On-Road 9 09-12-2006 07:15 PM
Wanted: Discharger and/or Discharger building info oMONSTERo R/C Items: Wanted to Buy 7 06-20-2006 06:24 AM
is this discharger a good one? Venom Battery Discharger aquito Electric On-Road 6 05-09-2006 02:21 PM
Duratrax 20 Amp Discharger, Indi Zerothirty-030 Discharger NOTFASTENOUGH R/C Items: For Sale/Trade 8 05-05-2006 08:07 PM
Wanted Integy Octane 2 Discharger or Trinity Realtime 2 Discharger FUK_WRX R/C Items: Wanted to Buy 0 08-02-2003 05:23 AM
