[Sharing] Construction of TT-02D
Having taken a break of over 10 years from RC, recently I got back into this hobby. Originally I wanted to get a TB-04, but due to several reasons, mostly cost, I decided to build a TT-02D instead. This has plenty of attractions for me as it comes with many upgraded parts as well as bonus options, such as ESC and Tamiya TLU.
https://scontent-hkg3-1.xx.fbcdn.net...c5&oe=567D2179 Things have changed a lot since I last played RC. Having done some homework on what types of cars there are and their costs, I decided to get the TT-02D version, which is a basic model but with drift capabilities. Motor, heat sink, ESC, drift tyres along with the bonus of Tamiya LED Unit come as standard. https://scontent-hkg3-1.xx.fbcdn.net...78&oe=563791D7 https://scontent-hkg3-1.xx.fbcdn.net...ef&oe=564D04B1 Construction started. Here is the chassis tub with front and rear gears installed, along with the drive shaft and motor. https://scontent-hkg3-1.xx.fbcdn.net...f0&oe=567C8B2C Battery and other bits and bobs of electronics fitted. https://fbcdn-sphotos-f-a.akamaihd.n...d745481efc674a Here is the finished chassis with custom grip wheels installed. https://fbcdn-sphotos-f-a.akamaihd.n...ce43f03d0029cc Despite the car being a drift car, I didn't like the Skyline GT-R body much, so I got myself a LaFerrari body. https://fbcdn-sphotos-e-a.akamaihd.n...c8d0afa3179531 This body is a fit for many chassis types, including mine and the popular mid-level race cars TA-06 and TB-04. https://scontent-hkg3-1.xx.fbcdn.net...1a&oe=56405BD9 Factory masking tapes in place https://fbcdn-sphotos-f-a.akamaihd.n...873fe0e6fe2ac9 but I wanted some customisation added to my car, so I did a little bit of custom-masking in various places, such as the bonnet and the roof. https://fbcdn-sphotos-e-a.akamaihd.n...cc8a780027960e Got myself these Tamiya spray paints. For polycarbonate bodies, PS paint must be used. These paints are different to the recommended codes by Tamiya in the instructions. https://scontent-hkg3-1.xx.fbcdn.net...38&oe=5638E691 The base red done. https://scontent-hkg3-1.xx.fbcdn.net...dd&oe=56373266 With the customised bits also added. https://scontent-hkg3-1.xx.fbcdn.net...bd&oe=56498289 https://fbcdn-sphotos-e-a.akamaihd.n...5c8a5422d76304 https://scontent-hkg3-1.xx.fbcdn.net...61&oe=5639A3F4 https://fbcdn-sphotos-g-a.akamaihd.n...6634ef2de69262 Didn't forget the plastic rear view mirrors. These were done with Tamiya's TS paints, with gloss added to give them a shiney surface. https://fbcdn-sphotos-g-a.akamaihd.n...abd605c20be3a9 I've also added some custom-made decals, based on the Ferrari 2007 title winning Formula 1 car - F2007. https://scontent-hkg3-1.xx.fbcdn.net...e9&oe=5648E398 Now, a decision has to be made on what tyres and rims to fit. Here is a photo showing the differences between a grip and a drift tyre. https://fbcdn-sphotos-d-a.akamaihd.n...4607700d9dbcf8 Next are the rims. The kit standard rims were stored away as I am not too fond of them. These are just two of many I got. The ones on the right are plastics, fairly durable and give plenty of performance due to their light weight, but they can chip badly from being used and abused. The left ones are made of metal, a little heavier than plastic ones, thus don't give as much performances as plastics, but they are good for looks. https://fbcdn-sphotos-c-a.akamaihd.n...960a18739c8595 In the end I decided to fit red-colour rimmed drift tyres, to go along with my spinning LED wheel lights. https://scontent-hkg3-1.xx.fbcdn.net...e2&oe=5654BCB5 This is how the wheels look from the side when stationary... https://scontent-hkg3-1.xx.fbcdn.net...20&oe=56540913 ... and how they look when the wheels are spun up, lighting the wheels like a race car stamping on the brakes hard, giving a fierce red glow through the rims. https://scontent-hkg3-1.xx.fbcdn.net...31&oe=563E9955 Finally, under-chassis lights added. Here is the finished product. https://scontent-hkg3-1.xx.fbcdn.net...dc&oe=5639F40D https://fbcdn-sphotos-f-a.akamaihd.n...af8e90462f6502 https://scontent-hkg3-1.xx.fbcdn.net...fd&oe=564D5336 https://scontent-hkg3-1.xx.fbcdn.net...e3&oe=5646DE1E https://fbcdn-sphotos-g-a.akamaihd.n...be2e999cdef339 https://scontent-hkg3-1.xx.fbcdn.net...ac&oe=563F9437 https://scontent-hkg3-1.xx.fbcdn.net...20&oe=563BDB3E https://scontent-hkg3-1.xx.fbcdn.net...bf&oe=563C06BD So what happened to the kit-Skyline GT-R34 body? Well here it is, looking ordinary and subtle. This will be a body for me to use in bashing the car about, so no remorse in any damages ;) |
You would be better posting this at www.tamiyaclub.com
Will receive much more interest there I would say. They have a section dedicated to builds. |
Thank you cplus :)
hi i have a question. based on the manual, the recommended servo size is
width: < 20.5mm length: 38 - 41mm height: 12 - 16mm + < 30mm will a 40.5×26×21mm servo fit. only the width is longer by 0.5 mm |
Originally Posted by changkh
(Post 14140010)
width: < 20.5mm length: 38 - 41mm height: 12 - 16mm + < 30mm will a 40.5×26×21mm servo fit. only the width is longer by 0.5 mm The servo is installed on its side (it's biggest flat surface to the chassis, see photo here: https://scontent-hkg3-1.xx.fbcdn.net...f0&oe=567C8B2C), so width shouldn't be a problem. The servo I use is a Futaba S3003. |
:eek: So much effort into the looks and you leave the body posts that long? :cry:
Originally Posted by kristianecyrus
(Post 14142464)
Hi changkh. I didn't check or follow the manuals when I installed mine, so I have no idea if mine suits the requirements or not.
The servo is installed on its side (it's biggest flat surface to the chassis, see photo here: https://scontent-hkg3-1.xx.fbcdn.net...f0&oe=567C8B2C), so width shouldn't be a problem. The servo I use is a Futaba S3003. i am concern the extra 0.5mm width will cause the servo post not able to sit on the chassis. |
Originally Posted by DirkW
(Post 14142524)
;) I plan to use several bodies. The LaFerrari is for display use. Skyline for bashing the car about and I plan to use a minivan body just for fun, so I need those tall pillars in place. :D |
(Post 14142746)
thanks for the reply.
My car with the Skyline body drifting
Tamiya TT-02D Skyline GT-R34 drifting Tamiya TT-02D Skyline GT-R34 drifting at night |
