Any reason not to run this ESC in 1/10 touring 17.5? >
Old 08-04-2015, 02:55 PM
Trader Rating: 38 (100%+)
Default Any reason not to run this ESC in 1/10 touring 17.5?
So, i'm trying to minimize the amount of electronics I have to purchase to run 2 classes. I'm running offroad 2wd buggy with a Trackstar 120A ESC (link below) and I'd love to purchase another to use in my 1/10 onroad 17.5 touring car. This way I'll have a backup if either of them has an issue.
http://www.hobbyking.com/hobbyking/s...ackstar%20120a
Is there any reason not to run this ESC for 1/10 touring 17.5?
Also thinking about this servo...thoughts?
http://hobbyking.com/hobbyking/store...g_0_06Sec.html
I'm a complete n00b in touring and dont even have a car yet. But looking to purchase something asap. Just trying to learn the dos/donts of touring.
xjwolfpacker is offline
Old 08-04-2015, 03:34 PM
svndayNZ's Avatar
Trader Rating: 20 (100%+)
Spend a little more and get yourself a hobbywing just stock, most of the guys I race with have blown these Turnigy's up within a handful of race meets.
Don't do it
svndayNZ is offline
Old 08-04-2015, 03:54 PM
I haven't used that esc but it has good reviews. The other 120a esc hk sells I do have and it's very good. Since you already have one your review should be as good as any!
I do have that servo and it's good but power hungry. You might need to use a capacitor for it.
2uzferunner03 is offline
Old 08-05-2015, 11:20 PM
Default 80 a
I have 3 of the 80a esc's being runing them for over 3 months, with 17.5 trackstars, lrp, and team powers motors. No problems and easy to setup, totally recomend.
Houtxracer is offline
Old 08-06-2015, 02:11 AM
I have both the 120 Turbo and the 80a. Both are really good and have not given me any problems. I'm not gentle on them either.
I race with the 80amp as it is ROAR approved.
filippimini is offline
Old 08-06-2015, 03:02 AM
howardcano's Avatar
Trader Rating: 37 (100%+)
The 120A is now ROAR-approved, too.
howardcano is offline
Old 08-06-2015, 03:29 AM
I have the 80A and they work fine. The only issue is that the drag brakes are a little weak. I also have a couple of their genII 120A and they are excellent.
old_dude is offline
Old 08-06-2015, 03:33 AM
You will need the card to programm it though.
old_dude is offline
Old 08-06-2015, 09:24 AM
DBM
I have the 120a and 80a versions of that esc with a combined ~700 packs through them. Both have been flawless. I also ran the 120 in my 4wd sct with a 5turn 550 truck motor. It worked great.. Here is where it didnt work quite as well....when you run lots of boost. The more boost you run, the weaker the brakes are. For dirt, that's fine, but on carpet in mod sedan, running a low turn motor with low boost is better than a higher turn motor with lots of boost.
I had the 80a on a dyno and the numbers were in line with the other big names.
DBM is offline
Old 08-07-2015, 05:48 AM
Thanks. I ended up ordering a second 120A to go in my TC. This way i'm running the same ESC in both my TC and 1/10 offroad buggy and can swap one out if I have any issues. And I only need 1 program card.
