Old 10-30-2005, 09:50 AM   #46
beerbarron's Avatar
Remington Spray lube with PTFE. It drys like a film and is teflon impregnated. Smells good too!
beerbarron is offline   Reply With Quote
Old 10-30-2005, 10:54 AM   #47
Stefan,
Please e-mail me at [email protected]
Thanks,
Craig
Hyper1 is offline   Reply With Quote
Old 10-30-2005, 11:02 AM   #48
Scottmisfits's Avatar
3 in 1 oil, sewing machine oil, paintball oil, something like that. You may need to do it a little more often. It's not a really thin oil but it's not thick either. It's a nice midgrade viscosity. It's what I use and it works well in the rigors of off-road as well as the smoothness(that I don't have) of onroad. I used it in my XXXS G+ when I had it. The only bearing I have ever had fail on me were in my clutch bell on my 1/8th buggy. Other than that, mine all work great.
Scottmisfits is offline   Reply With Quote
Old 10-31-2005, 05:56 AM   #49
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
I lube with Marvel Mystery Oil for motor bearings and wheel bearings works pretty good for me.
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 10-31-2005, 10:23 AM   #50
I use Mobil 1 in my bearings. If your shocks leak and you add Mobil 1 to them, it can often stop the leakage.
If you use Militec don't let it touch any o-rings or rubber seals (for example your shocks) not unless you want leakage.
PS. You don't want "slippery" oil in your shocks. No Teflon or anything like that. Teflon makes the balls skate inside the bearings, creating heat and premature wear. Balls in ball bearings are supposed to be turning not slipping.
andsetinn is offline   Reply With Quote
Old 10-31-2005, 02:10 PM   #51
For those guys who are using Mobil 1, can you tell me how often do you have to re-oil your bearings?
My friend have tried that before but the bearings die very quickly (less than 3 months )
yellow15 is offline   Reply With Quote
Old 11-01-2005, 07:24 PM   #52
anyone?
Old 11-01-2005, 09:16 PM   #53
Charlie O's Avatar
Remington, RemOil with teflon, this is their traditional type oil, i will swear by it!
Charlie O is offline   Reply With Quote
Old 11-02-2005, 04:10 AM   #54
NOZ69's Avatar
I use Kluber Lubrication Paraliq 91...it`s a high performance oil spray used on high speed industrial knitting machines.
Bloody fantastic stuff
I`ve also used automatic transmission fluid
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 11-02-2005, 05:26 AM   #55
VenomWorldOrder's Avatar
depends on a few things:
-how often you clean the dirt of the bearings that stick around it,
-how often you tear your car down.
-were you race (is it dusty? do you race with foams?)
-how you oil the bearing (i oil it, let it sit a few days, then oil it again)
bearings shouldn't die in 3 months. but if they are metal sheild only you have to clean them more often. get a set of rubber sealed jobbers if you kill bearings every 3 months.
VenomWorldOrder is offline   Reply With Quote
Old 11-02-2005, 05:55 AM   #56
whoopass's Avatar
3 words 'Zubak speed lube'
whoopass is offline   Reply With Quote
Old 11-02-2005, 06:06 AM   #57
Originally Posted by Davidka
I would give Pro Gold (also known as Pro-Link) bicycle chain oil a try. It is as thin as water but has amazing film strength. I use it on my bikes and my chain stays quiet for 200+ miles. Works great in bearings and doesn't attract nearly as much dust as normal oils.
yep good stuff its what i use and works well.
bob33 is offline   Reply With Quote
Old 11-02-2005, 03:40 PM   #58
17driver's Avatar
R/C Tech Charter Subscriber
I'll second that!
Midwest malitia member
17driver is offline   Reply With Quote
Old 11-02-2005, 04:07 PM   #59
Davidka's Avatar
Trader Rating: 77 (100%+)
another oil I used in the past was a gun oil called Break Free. It breaks up gunk in the bearings really well, it seemed like you could run the bearings cleaner.
Old 11-02-2005, 04:25 PM   #60
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
well done rob
you beat me to it
Zubaks stuff real good even the speed juice
but the lube yes indeedy especially for bushings on 27t & wheel bearings
we`ve tried all sorts of gear in the uk
Zubaks for me
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Tungsten Disulfide engine pre breakin Lubricant Relay8039 Onroad Nitro Engine Zone 14 12-28-2010 09:50 AM
PowerKote lubricant for off-road? captain america Electric Off-Road 1 11-29-2010 03:58 AM
WTB: TRIBO R/C Power Matrix Commutator Lubricant Buggy Master R/C Items: Wanted to Buy 8 07-23-2007 08:54 PM
lubricant spray any parts? zax Electric On-Road 0 09-12-2005 02:05 AM
Bearing Lubricant rcfaster Electric On-Road 13 05-12-2005 06:19 PM
