Old 10-29-2005, 08:45 AM   #16
Trader Rating: 22 (100%+)
Send a message via AIM to 5thscaleracer
Originally Posted by WD40
I have an opinion on this that differs from many people. I think that maybe a little thicker lubricant is better than the thin oils that people are putting on bearings today. A very thin oil applied to the bearing will spin out after the first run. A thicker oil will stay inside the bearing for longer. Now I know some of you are saying, the thicker the oil the more friction, which is true.....but some oil in your bearings after the first run is better than no oil. Also the thicker oil thins and viscosity decreases as the bearings heat up. Just my two cents worth to my own question. If anyone disagrees or knows a very good lubricant for the bearings please let me know.
actually you will need an oil that bonds to the surface of the bearing racea and the balls. it's not simply just an oil that you put in but it has to actually put a surface coat on all the rotating components. The royal oil works but it's just a lube if you run bearings with you seals it's useless. There are oils that have MOS2 which is a moly type lube this will bond to conventional SS balls and coat it. it's very thin and will last half the life time of the grease so reapplying is required.
i personally use the MOS2 lube made by lubromoly they make a small pen oiler. another good brand is Tufoil if you can fidn it still i have some but it's getting on the low side.
5thscaleracer is offline   Reply With Quote
Old 10-29-2005, 09:16 AM   #17
thecrow2k's Avatar
http://www.paragon-products.com/product_p/lm3010.htm
WHAT that, i found it after 10seconds on google
thecrow2k is offline   Reply With Quote
Old 10-29-2005, 09:21 AM   #18
stefan's Avatar
Send a message via AIM to stefan
An oil that survives the heat and pressure inside your engine at 6000 rpm, should be able to cope with a ball bearing, right?
Mobil 1 0W-30
stefan is offline   Reply With Quote
Old 10-29-2005, 09:39 AM   #19
I have metal sealed bearings in my touring car. I soaked them in motor spray over night to get all the extra grease out. I was just wondering what some experts recommend for lubrication for the bearings? I would like something that can get in the seals without taking them off if possible. I want my drivetrain to roll as smooth as possible. Any help would be appreciated.
This stuff is awsome http://www.militec-1.com/products.htm
pops is offline   Reply With Quote
Old 10-29-2005, 09:51 AM   #20
My opinion:
1. Clean ball-bearings with pure gasoline.
2. Turn them and use brake cleaner (those from real cars use).
3. Again gasoline.
4. Then clean them with WD-40.
5. Again gasoline and let them dry.
6. Pure into them some thin oil as our ball-bearings are small and don't have the load of a real car!
For me is important to use after every step gasoline so as to work at each step with no leftovers from the previous one.
I use LRP and Trinity bearing oil with the last one better.
The bb will take the ml that really requires and the other will just go out!
Capone_GR is offline   Reply With Quote
Old 10-29-2005, 10:05 AM   #21
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by pops
I tell you it is good to be retired military...major discount...Thanks pops...you know me always trying new stuff...
How thin is it...????
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-29-2005, 10:06 AM   #22
Trader Rating: 29 (100%+)
I wouldnt recomend useing gas to clean any thing, the chance of a fire is way to high, remember a lot of kids read this forum, and even some adults dont realize how dangerous that can be, there are lots of things you can use
that, clean well.......
Mdoc is offline   Reply With Quote
Old 10-29-2005, 11:14 AM   #23
Default oils.......
another Mobil 1 0-30 user........
And there are even thinner racing motor oils out there. I have some "00000" Synergy that's like water, but has really good film strength. Supposedly used by the pro stock drag racers.....Not sure if Synergy is still in business. Got it many years ago, still have 1/2 a qt or more......
Manning is offline   Reply With Quote
Old 10-29-2005, 12:02 PM   #24
what's so good about the Mobil 1 0-30? our bearings are spinning a lot faster than 6000rpms.
Hyper1 is offline   Reply With Quote
Old 10-29-2005, 12:31 PM   #25
-Shookie <><
It is pretty thin, yet it seems to coat very well and stays in place. They use to give away samples to everyboday, I even got some of their grease, works very well for your outdrive slides.
Old 10-29-2005, 12:34 PM   #26
I use slide oil for trombones!
John Warner is offline   Reply With Quote
Old 10-29-2005, 02:23 PM   #27
Interesting,I used to play trombone in college.
Old 10-29-2005, 02:27 PM   #28
Nicadrauspro4's Avatar
Try this:
Get a tin can and put your bearings inside. Spray your bearings in the can with WD-40 until soaked. Heat the can's bottom with low fire (from a stove or burner) for about 2 mins. Heating it will help the lubricant get to all the areas inside the bearings. Use gloves because the can get very hot. Shake the can sideways for a minute after heating. It will remove all the dirt stuck into it wihile shaking. Then take the bearings out and let it cool down then wipe it with clean clothe or spary with compressor. Your bearings should be ready. No need for any other lubricants. It's very effective.
Note: Keep the fire low because WD-40 is flammable. Be very careful when heating. Do it outdoors.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 10-29-2005, 02:54 PM   #29
RandomFellow's Avatar
Wow, lots of good lubricants for me to try!
Right now, though, I've been very happy with Tribo R/C Power Matrix. AND, its great for your comm as well.
RandomFellow is offline   Reply With Quote
Old 10-29-2005, 03:10 PM   #30
Yep, I find it has worked very well for the past several years now. One plus is it doesn't attract or hold dust!
Tungsten Disulfide engine pre breakin Lubricant Relay8039 Onroad Nitro Engine Zone 14 12-28-2010 09:50 AM
PowerKote lubricant for off-road? captain america Electric Off-Road 1 11-29-2010 03:58 AM
WTB: TRIBO R/C Power Matrix Commutator Lubricant Buggy Master R/C Items: Wanted to Buy 8 07-23-2007 08:54 PM
lubricant spray any parts? zax Electric On-Road 0 09-12-2005 02:05 AM
Bearing Lubricant rcfaster Electric On-Road 13 05-12-2005 06:19 PM
