Old 12-30-2002, 06:01 PM   #181
Is that for stock or mod?? I will be running mod on the newer ozite if that helps any.
Ben_Busta is offline   Reply With Quote
Old 12-30-2002, 09:39 PM   #182
litespeed-dom's Avatar
Mod, I run a 10X2 w/ 3300 GP batts.
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 12-31-2002, 10:51 AM   #183
So you decided that the .075 t-bar was better after all? In earlier post you were saying you didn't like it. Thanks for the help. This is my second 12th scale. My first was a Carpet Knife 3.1. Boy was that a big mistake. The Yok was so much faster than the CRC, but the CRC was very easy to drive. I just can't see it ever being very fast like an t-bar can be.
Old 12-31-2002, 11:09 AM   #184
You sure that was me? (I'm too lazy to read all my posts on this thread). I'd only used the thinner t-bar in one race and it was OK, not GREAT. All my 075 t-bar runs were faster than the Yok t-bar runs. It's really a personal preference, Skid Marks swears by the Yok t-bar, I like the .075 myself.
Yeah, the Carpet knife is a pig, I race it in one race last year and I couldn't wait to get rid of it. Too many moving parts, too heavy, doesn't transition well. With the Yok, it's not much of harder to drive, but it requires you to be more finese, can't just throw the car into the corner.... makes you a better driver anyway.
Old 12-31-2002, 12:01 PM   #185
Oh well, maybe it was someone else. Thanks for the help. The only different thing I'm going to try is white rears and double pink fronts. The purple ang greys are good, but I think for the track we run on more traction is needed. It is the newer Ozite from what I hear now, so the purple grey seems to hard for traction, but We will see what happens. Thanks again.
Old 01-10-2003, 07:46 AM   #186
Trader Rating: 45 (100%+)
I noticed yokomo is making a hard and a soft chassis for the yrx-12 now. What is the difference between the two? Is the hard one just thicker? If so, what is the thickness?
Apex is offline   Reply With Quote
Old 01-10-2003, 09:21 AM   #187
2.1mm and 1.9mm thickness. To do with traction issue.
Old 01-12-2003, 07:11 AM   #188
thanks litespeed-dom...
Old 01-13-2003, 07:41 PM   #189
i was wondering what parts you brake most when racing this car, and how much the parts cost?
blue micro is offline   Reply With Quote
Old 01-13-2003, 08:02 PM   #190
I've broken the front graphite brace, I know 2 friends of mine both broke theirs already. That part is real flimpsy so I got the AE L3 front brace, cut it down (the Yok chassis is narrower than an L3) and used that instead, no more buying that $6 part!
Old 01-13-2003, 08:24 PM   #191
wheres a good place to find one of these, i hear there pretty hard to find? also what else will i need? i have a quantum comp. and a radio with a XXL, but am not sure what servo to get? are those good electronics for this car? does it come with tires and wheels?
Old 01-13-2003, 08:28 PM   #192
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Default ok guys !! how about some setups!!
I ALSO OWN ONE OF THESE LIMITED CARS.. HOW ABOUT COMPARING SETUPS..
.20 SPRINGS
MIDDLE CASTER
1.5 DEGREE CAMBER
0 TOE-IN
PURPLE TRCS SINCE THEY FIT BETTER THAN JACO/PROLINE
FULL TIRE COMPOUND OR 3/4 OF TIRE.. PARAGON SAUCE.
REAR
SHOCK OIL= 30WT.
BLUE SPRING.
ASSOCIATED THICKER T-BAR (.070) ????
GRAY TRC WHEELS
FULL TIRE SAUCE.
RIDE HEIGHT 3MM FRONT AND REAR.
2ND TIME RUNNING THE CAR AND FINISHED 1 LAP BACK FROM EXPERIENCED DRIVER.. FINISHING 2ND. NOT BAD.
RCFREAK is offline   Reply With Quote
Old 01-13-2003, 08:51 PM   #193
Default Re: ok guys !! how about some setups!!
.20 SPRINGS
MIDDLE CASTER
1.5 DEGREE CAMBER
0 TOE-IN
REAR
SHOCK OIL= 30WT.
BLUE SPRING.
GRAY TRC WHEELS
FULL TIRE SAUCE.
Active caster or non-active caster?
Old 01-13-2003, 09:27 PM   #194
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default Re: set up
Try this :
0 degrees toe in
Reactive Caster front end
Both caster shims in forward position
18 front spring( 20 if track is grippy or to suit driving style)
Yokomo 2 degree axles (kit comes with 3 degree axles)
Trinity red stuff on polished front kingpins (bail on the ti ones steel are smoother)
Assc 070 Tplate
Blue spring ( silver if grip is low)
Yokomo 450 oil in shock
Rbrc thrust lube on damper plate..this is critical as it is med to heavy and tacky and slow the car down side to side and helps compensate for flexy nature of the car.
Front tires (trc magenta and 1/4-3/4 compound to suit track and driving style
Rear tires (trc grey full compound...white if the track in not that grippy)
Yokomo 12th body
J.Gonzalez is offline   Reply With Quote
Old 01-13-2003, 10:12 PM   #195
I don't use any kind of lube at all, picks up all kinds of fuss from the carpet., especially on the kingpins. I use CRC teflon rear pod discs and teflon tapes on the graphite plate so the rear of the car actually moves left and right a lot smoother. I also use Paragon Ti damper post so when the rear pod moves, it free flows when the rear shock is being compressed and when it's moving left and right. I tried all the lube at kingpins and rear pods, it makes the car too sticky and doesn't transition well at all.
YOKOMO YRX12 WORLDS 12Th SCALE + MORE HarshGuy R/C Items: For Sale/Trade 4 07-24-2004 09:30 PM
NIB yokomo YRX-12 Worlds Edition 1/12th Scale SSG fastang347 R/C Items: For Sale/Trade 6 01-26-2004 04:18 PM
yokomo YRX-12 Worlds Edition 1/12th Scale SSG fastang347 R/C Items: For Sale/Trade 20 12-16-2003 12:58 AM
Yokomo YRX 12th scale Worlds Edition $75 sipaboy R/C Items: For Sale/Trade 5 11-23-2003 10:23 AM
Yokomo Yrx-12 Worlds Edition 1/12th Scale Lee H R/C Items: For Sale/Trade 10 11-05-2003 11:25 AM
