Like Tree188Likes
Motiv RC
    Hide Wikipost
Old 02-13-2019, 04:00 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Motiv RC
Last edit by: Johnny Carey
NEW FOR 2018!
  • Defy G, Graphene LiPos
  • More Coming Soon...
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
John's Mobile Raceway / 180 Raceway
& More - Check your local hobby shop!
Defy Series Pro Li-Po batteries
MOV2015: GREY GRAPHENE PRO LIPO, 2S SHORTY
  • COMMON APPLICATION: Stock 10th Off Road, Mod 10th off road, F1
  • 95.5mm Length X 46.5mm width X 24.5mm height
  • 5000 MAH, 2S, 100C, 7.6V, 38WH.
  • 5mm through Bullet
  • Weight: 202g
  • COMMON APPLICATION: Stock TC, 4WD Shortcourse, Stock Dirt Oval
  • 137.5mm Length X 46.5mm width X 24.5mm height
  • 8400 MAH, 2S, 100C, 7.6V, 63.8WH.
  • Weight: 329G
MOV2018: GREY GRAPHENE LOW PRO LIPO
  • COMMON APPLICATION: Mod TC, Loose Track Mod Dirt Oval
  • 138.5mm Length X 46.5mm width X 22mm height
  • 6000MAH, 2S, 100C, 7.6V, 45.6WH
  • 5mm Through Bullet
  • Weight: 273g
  • Low CG
MOV2037: LOW PROFILE GREY GRAPHENE 2S LP Shorty
  • COMMON APPLICATION: Mod Offroad, F1
  • 92.7mm Length X 46.5mm width X 18.5mm height
  • 4100MAH, 2S, 90C, 7.6V, 30.4WH
  • Weight: 153g
  • Low CG
MOV2001: V6000 LIPO
  • COMMON APPLICATION: Stock & Mod 1/12 On-Road and Oval
  • 6000MAH, 1S, 90C+, 3.7V, 22.2WH
  • 4mm Bullet
  • Weight: 150g
MOVXXXX: GREY GRAPHENE PRO LIPO, 1S
  • COMMON APPLICATION: Mod 1/12 and Oval
  • 8200MAH, 1S, 100C, 3.8V, 31.2WH
  • 4mm Bullet
  • Weight: 150g
MC2 Series Brushless Motors
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Old 05-14-2019, 01:22 PM
  #1081
Default Motiv has the best customer service
I just wanted to give my experience of Motiv customer service and in particular Paul.L
I emailed Paul regarding an issue with my MC3 and I attached a video. Paul responded within 2 days and decide to replace the motor. The issue was with the stator and didnít think it needed replacing but he didnít want to beat around the bush and wanted me to have a motor that was performing well.
I never exeprineced customer service like that before in RC.
Also the cherry on the cake is that he was happy to post it to the UK.
Waztrain1234 is offline
Old 05-15-2019, 03:57 PM
  #1082
eR1c's Avatar
I love hearing stories like this,
also just another reason why I spend a little more for quality and customer service. Let's keep supporting companies w/ great customer service that are helping our hobby.
I do love Motiv's motors (my last Motiv motor came w/ a hand note stating where the best timing was for my motor, ...i've never adjusted it and it runs GREAT).
eR1c is offline
Old 06-08-2019, 06:25 PM
  #1083
theproffesor's Avatar
Trader Rating: 63 (100%+)
Can anyone tell me the weight of the defy G 6000mah low cg pack? Itís the one battery without a weight listed on the website
theproffesor is offline
Old 06-08-2019, 07:18 PM
  #1084
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
If it's a shorty 219g, if regular 288g
drivercorycraig likes this.
RKeasler is offline
Old 06-13-2019, 08:27 PM
  #1085
BadSign's Avatar
Trader Rating: 15 (100%+)
I recently contacted Paul with an issue on the 17.5 MC3 I was using in 12th scale. Paul replaced the sensor board and the rotor (which wasn't necessary, but he didn't like the look of it) and returned it quickly. I couldn't be happier with the service from Motiv.
Oh yeah, my car is a rocketship with that motor. Now I need to buy some skill to drive it.
BadSign is offline
Old 06-15-2019, 01:16 AM
  #1086
Default Rotors
Hi
does anyone know difference between the 1318 and 1330 rotor ?
Old 06-25-2019, 11:15 AM
  #1087
Dan
Dan's Avatar
Trader Rating: 64 (100%+)
Anyone compare the MC3 25.5 to the MC2? Thoughts?
eR1c likes this.
Dan is offline
Old 07-24-2019, 03:00 PM
  #1088
long pack is like 270g
shorty is 240?
drivercorycraig is offline
Old 07-24-2019, 03:02 PM
  #1089
MC3 is stronger than the MC2 25,5 and 21.5 that i have experience with.
Both MC3s have more bottom end than the MC2 but retained the top end.
I have 25.5s in both my F1 and VTA and i gained a tenth in both simply swapping to the MC3.
the 21.5 in my USGT id argue is a tenth or more faster than the MC2.
Other folks around the area have similar stories. They are fantastic and the shop i work at we can not keep any of them in stock from 25.5s down to 10.5s
eR1c and Adam W. like this.
Old 07-30-2019, 09:49 AM
  #1090
eR1c's Avatar
I am starting to look for a new 25.5 VTA motor,
thinking the MC3 or the new XFactor from Trinity (which I have in my 17.5 and love), yet I have been using the MC2 for the past 2 seasons in my VTA with great results. Maybe I am splitting hairs at this point?!
Thoughts??
eR1c is offline
Old 07-30-2019, 10:29 AM
  #1091
Adam W.'s Avatar
I have been running a Revtech since January and when I first got it I was running towards the front of the pack. Now that I've used it a bit and other guys have moved up to a MC3 I'm more mid to back of the pack. I just got my MC3 and I can't wait to try it out. I have overheard people say that the Revtech is good new but loses some power as it gets used and I think that's what I am experiencing.
Adam W. is offline
Old 08-04-2019, 06:23 PM
  #1092
Does anyone have a starting FDR recommendation for 17.5 MC3. 40x80 black carpet technical track. Just want a ball park to start tuning from
Ctennispro225 is offline
Old 08-10-2019, 01:48 PM
  #1093
trying again. Racing tomorrow and wanted to get some practice with the 17.5. The only reference I saw in this thread was for 3.95 FDR. Is that correct?
Old 08-11-2019, 11:08 PM
  #1094
hairymuffin's Avatar
Trader Rating: 102 (100%+)
Anyone know if the high power rotor for the mc2 will fit the mc3? I only see the mc2 rotor..
hairymuffin is offline
Old 08-12-2019, 10:49 AM
  #1095
got my answer from gravity, itís the same rotor
