Like Tree120Likes
Motiv RC
    Hide Wikipost
Old 01-19-2018, 04:42 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2018!
  • Defy G, Graphene LiPos
  • More Coming Soon...
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
John's Mobile Raceway / 180 Raceway
& More - Check your local hobby shop!
Defy Series Pro Li-Po batteries
MOV2015: GREY GRAPHENE PRO LIPO, 2S SHORTY
  • COMMON APPLICATION: Stock 10th Off Road, Mod 10th off road, F1
  • 95.5mm Length X 46.5mm width X 24.5mm height
  • 5000 MAH, 2S, 100C, 7.6V, 38WH.
  • 5mm through Bullet
  • Weight: 202g
  • COMMON APPLICATION: Stock TC, 4WD Shortcourse, Stock Dirt Oval
  • 137.5mm Length X 46.5mm width X 24.5mm height
  • 8400 MAH, 2S, 100C, 7.6V, 63.8WH.
  • Weight: 329G
MOV2018: GREY GRAPHENE LOW PRO LIPO
  • COMMON APPLICATION: Mod TC, Loose Track Mod Dirt Oval
  • 138.5mm Length X 46.5mm width X 22mm height
  • 6000MAH, 2S, 100C, 7.6V, 45.6WH
  • 5mm Through Bullet
  • Weight: 273g
  • Low CG
MOV2001: V6000 LIPO
  • COMMON APPLICATION: Stock & Mod 1/12 On-Road and Oval
  • 6000MAH, 1S, 90C+, 3.7V, 22.2WH
  • 4mm Bullet
  • Weight: 150g
MOVXXXX: GREY GRAPHENE PRO LIPO, 1S
  • COMMON APPLICATION: Mod 1/12 and Oval
  • 8200MAH, 1S, 100C, 3.8V, 31.2WH
  • 4mm Bullet
  • Weight: 150g
MC2 Series Brushless Motors
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Old 09-22-2018, 04:26 PM
  #931
Has any body tried fitting ceramic bearings into their motors ? What have you gained?
Waztrain1234 is offline
Old 09-24-2018, 07:27 AM
  #932
Congrats Paul on another National Championship.
STLNLST, qcrc and jlfx car audio like this.
freebird is offline
Old 09-29-2018, 09:28 AM
  #933
Default Sensor board
Hi
i have repalced my sensor board on my MC2, it was never accurate when I got it as it was out by 4*. Since I have replaced it is within 1* ( 40, 41 , 40) so very accurate now. So my question is what can I expect to gain with a more accurate sensor board?
I initially thought I would be getting a higher KV but I didnít see any gains.
Old 09-29-2018, 12:48 PM
  #934
bertottius's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Waztrain1234 View Post
Hi
You should get a more consistent motor all around. I've seen a rise in RPM and efficiency on my dyno after I adjust the sensors. If you don't see any gain, you might not have the timing the same? What motor checker are you using?
bertottius is offline
Old 09-29-2018, 01:27 PM
  #935
I have a Gforce motor analyser, I origanly had it set at 40* on the motor but when putting It on the analyser timing was 37* (it was pulling around 2.7amps and showing Kv between 4025 -4050. So I did the same when I put the new sensor board in. So I set the motor at 40* so it was now reading 40* on the analyser, it was pulling 3.2amps and showing Kv of around 4075.
I dont have a dyno, I will be testing it on the track next week.
The analyser that I have is the same black rebranded one you can get online from most rc retailers.
Old 10-07-2018, 03:16 AM
  #936
Hi all
The mc2 ran flawlesy last night, I couldnít believe the difference in performance of the motor being 135-140f compared to 165f. Last nights I ran it with a fan in my gt12 (itís a 1/12 car, based on a LMP), the motor was consistent all the way through the run without any drop off. Itís felt the same at the start compared to the end of the run.
I settled on 42* of timing, i was at 44* but went down by 2 due to it being a very twisty infield.
bertottius likes this.
Old 10-09-2018, 01:28 PM
  #937
Hi
Usually a more efficient motor - should lower operational temps slightly. While 4* is substantial - it's not that much out of whack that it will cause significant reaction in the motor.
duckman996 is offline
Old 10-11-2018, 07:51 PM
  #938
Still Bill's Avatar
I assume that the new Motiv MC3 will not be allowed at the IIC in November because Scotty already posted an approved motor list dated May 2018.
Anyone know for sure?
Still Bill is offline
