Motiv RC
#828
Hi
Just little update.
I have spent more time with my 13.5t MC2 on the motor analyser. I have found that increasing the timing had little affect on Kv as it remained the same at 41* as it did at 44*. So I have settled on 41* as it gave the same rpm/Kv at lower amp draw.
Has anyone else experienced this ?
I have ordered trinity timing screws, so I will see how that affects the Kv. Has anyone else tried them? I have already used the long aluminium screw and saw an increase of around 175-200kv.
Just little update.
#830
The amp draw at 41* is 3.1 and at 44* is 3.6.
The Kv I got at 41* was around 4150-4180
#832
In short yes
To be honest I didn’t have a set method of setting timing on a motor. I only recently got the motor analyser so I was just playing around with it and it was something that I noticed.
To me it didn’t make sense to keep increasing the timing when you didn’t see any or very little increase in Kv. It makes more sense to keep the timing a little lower, with slightly less Kv and lower amp draw. The motor will run cooler with less fade.
I’m looking forward to testing it on the weekend.
#833
Tech Legend
In short yes
#834
waztrian, you have the correct idea. it's how I was doing that before I got my dyno. more timing puts more heat in the motor without much performance gain
#835
I wouldn't completely rule out more timing. I've taken my monster max 13.5 to 8 amps and dropped 2 teeth and it ran like a modified. The amp draw/performance curve is fluid. I think certain brands have sweet spots (R1@43), but not necessarily the best for a particular track.
#836
laguy, you have a dyno sheet for that?
#837
Morning (wel it is in the UK right now)
Just a follow up from my last message. I tested my MC2 13.5t with a mid rotor at 41 in my GT12 ( its very similar to 1/12, very popular in the UK)
The car was flying, I had it geared just right as it went down the strait. However, I had a bad night/luck (partially my due to my errors) at racing last night and the motors temps were high once I got a clean/good run. I struggled for grip for the first 2 rounds, temps were around 55c/131f. But once I got a clean run temps went up to around 85c/185f (at these temps there was noticeable fade). I have always found with the MC2 on a big track I need to run a fan but on a small or medium size track I don’t need to use one.
I will test it again on large track but I will try my timing around 36-38*.
Is the general consesnous to keep your MC2 below 160f/71c?
Can anyone provide information/details at what temps they have experienced motor fade/power loss?
#839
Jorge T - just to clarify, are you saying that there will be long term damage if the rotor reaches 180f ? My understand is that there will be long term damage if the motor continues to run hot.
My aim is to keep the motor below 160f.
#840
The new stators can take the heat and keep on going. Unlike in the past that the insulator melted if the motor overheated causing a short.
With all the new motors if the get hot (up to a point) a new rotor and the motor is strong again.
