Race Opt MTS T2/T3
#272
Super Moderator
thank you its working out pretty good so far , testing the car again this weekend outdoors then Black crc carpet saturday night and sunday. If the floating single bellcranck works out with the MTS I will swap it over to the Hybrid car saturday night.
Thanks Bartolo Racing for the parts support
#277
Super Moderator
single bell crank was a hit also! have to make a small mod to the mount sinse the servo on my hybrid was moved forward 2mm from stock but it should work just fine when its done. The car Tq and won on USGT today.
#281
Super Moderator
With the aluminum front hubs and a 3mm hexes the width is just about 1mm wider than stock .(The aluminum front hubs make the car a little wider so I had to replace the 5mm hex with 3mm)
The MTS-V3 with the White bomber ready for this weekend’s 17.5 invitational at Valkaria Florida
#282
Super Moderator
Made a few changes to my MTS-V3 hybrid added a floating single bell crank steering moved 4mm forward plus moved the servo forward about 3mm more than the previous spot with the dual crank steering. Maybe swapping to the full size lipo tomorrow since I may be running mod in a few weeks.
#283
Super Moderator
#285
Super Moderator
