Race Opt MTS T2/T3
#331
Super Moderator
problem is though, it may not be complete carbon, they like to produce it from frp, then put a top layer of carbon on it so it appears to be carbon, therefore have much more flex.
could be wrong though, will be looking at car over weekend as friend got one to see if its better choice to do 4wd mini conversion.
#332
#334
Super Moderator
Great weekend racing with Bartolo Racing and the MTS/V3 in 21.5 class. Clicked the fastest lap in the class 9.9(the only 21.5 car in the 9's), 17.5 guys were in the 9.5-9.7sec laps. Was within inches of the 1st place car thru the whole race , got up front for a few corners started to pull away, but got tangled up with lap traffic ended up finishing second.
The car so far is working very well. Next weekend will be at Valkaria for some racing before the Regional race there later this year.
#335
#340
#344
You can find my impressions about the kit here: http://www.rc4life.ch/2015/10/18/mts...-et-remontage/
The first thing I had to do was to re-design a chassis/upper deck for the car and ask Bezerk RC to cut it. It really transformed the car. You can ask him, I think he still has the plans.
Then I replace all the plastic parts by Xray parts, which are stronger. The thin arms are good in lower traction conditions, but when traction increases, you lost a lot of energy in curves and transitions. I think you have the same impression as you switch for cf arms :-)
I'm not racing the car anymore, but it was a fun car. At the end I was using my custom chassis/upper-deck with stands in the front and thickest flex bar in the rear.
#345
Super Moderator
I do, and the purpose of the specific design is to concentrate the flex on the flex bars, so you can have a lot of traction in the rear part of the chassis. It is working very well in the conditions I used the car (13.5 boosted, medium grip asphalt). I'm quite surprised to see that you are using the cf link on the rear, I've done the same because the car had way too much flex everywhere.
You can find my impressions about the kit here: MTS T-squared - Démontage et remontage | Rc4life
