Old 10-27-2005, 08:38 PM   #1
Cool gearing help
i have a 12 turn motor in my traxxes bandit. i was told i am way over geared cuse i am burning up my motor and batterys. i want to no wut way i need to go ont he spur gears. i was told to drop a few teeth on the pionion gear. i have a 26 tooth pionion gear in there now. and a 78 tooth spur gear. how many should i go down on the pionion gear and what way should i go on the spur gear and how many. or should i just change one of the gears?
weirdkid is offline   Reply With Quote
Old 10-27-2005, 08:42 PM   #2
you should run 22 or 23 with that motor ,, should be just right with a 23 .. also keep track of run time and motor temp ...
Mark Barden .
mb racer is offline   Reply With Quote
Old 10-29-2005, 08:18 PM   #3
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
I have no idea what to suggest for a gear ratio as I don't own a Bandit, but you could always try the offroad or even the Official Traxxas Forums.
As mentioned earlier in the other threads you made, you must use these connections: http://www2.towerhobbies.com/cgi-bin...&I=LXKX39&P=ML
Team Duratrax is offline   Reply With Quote
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
