Old 10-27-2005, 09:58 AM   #1
Default GFX Fuse ?'s
i have now blown 4 20 amps fuses, i was wondering if i could use a bigger amp fuse if that would help?
SPC Racer is offline   Reply With Quote
Old 10-27-2005, 10:02 AM   #2
CCristo's Avatar
Trader Rating: 55 (100%+)
That's not a good idea. The fuse is there to protect the internals. If the fuse doesn't blow it could cook something inside. Are the fusing blowing under normal use? If so, you might want to contact CE and have them check it out. I've only blown one fuse and that was because I plugged the ps lead in backwards.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 10-27-2005, 10:03 AM   #3
lastplace's Avatar
Send a message via Yahoo to lastplace
It would help cook your GFX When are you blowing the fuses?
lastplace is offline   Reply With Quote
Old 10-27-2005, 10:11 AM   #4
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
How are you blowing fuses?
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 10-27-2005, 10:48 AM   #5
Super Moderator
Trader Rating: 17 (100%+)
Just an FYI, two weekends ago I asked a bud a the track to discharge a pack for me at 30 amps. about a min into the discharge the GFX started spitting flames about a foot high out of the fuse area. When he sent it back they couldnt figure out why this happened. In fact the charger still worked. They did take care of him and send a new GFX out. Moral of the story is keep an eye on your fuses no matter how big or small you put in there.
Tekno|JConcepts|TeamTrinity|BOOMrc
Bob Barry is offline   Reply With Quote
Old 10-27-2005, 11:03 AM   #6
mudpuppy's Avatar
Under what circumtance is the fuse blowing?
This is kind of out there but if you hook your GFX to your battery pack before you hook your GFX to your power supply, the fuse will blow.
Always power up the GFX before attaching your battery.
mudpuppy is offline   Reply With Quote
Old 10-27-2005, 11:14 AM   #7
asw7576's Avatar
Is it because the GFX can't discharge full battery ?
Is there any reason not to discharge at lower amp ? for examples discharging at 25amp instead of 30amp ?
Old 10-27-2005, 11:30 AM   #8
it happened yesterday when i was going to start charging and it keep saying that there was an error and the voltage was to low and stoped charging
Old 10-27-2005, 12:57 PM   #9
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Default fuse
Not saying this is what you did, but the only time I have blown a fuse is when I hooked up the battery backwards, it gave the same error and blew the fuse.
Shopkeeper is offline   Reply With Quote
Old 10-27-2005, 01:05 PM   #10
Buck Nasty's Avatar
Also when you blow one fuse look at all three. If you have two blown fueses and only change one of them that one will keep blowing.
I think, therefore I'm single. Buck Nasty
Buck Nasty is offline   Reply With Quote
Old 10-27-2005, 10:01 PM   #11
CCristo's Avatar
Default power supply?
What is your power supply voltage and what power supply are you using?
Chris Cristo
Fuse jono mad racer Singapore R/C Racers 4 04-08-2007 06:27 PM
Rio Fuse F/S Viper212 Other Items: For Sale/Trade or Wanted to Buy 3 05-01-2005 06:38 PM
lrp pulsar fuse raceblast Electric On-Road 1 01-06-2005 08:01 AM
ESC Tekin 50A Fuse semcx R/C Items: Wanted to Buy 1 05-24-2004 09:47 PM
Need to get a fuse for ESC Ooj Australian Racing 0 01-14-2003 05:02 PM
