Need help finding some 15t center pulleys >
Old 07-18-2015, 02:12 AM
Default Need help finding some 15t center pulleys
If anyone can post a link or guide me where I can buy some 15t center pulleys. I would greatly appreciate it.
Juan Aveytia is offline
Old 07-18-2015, 02:53 AM
SagadSetup's Avatar
Trader Rating: 38 (100%+)
For which car?
SagadSetup is offline
Old 07-18-2015, 08:20 AM
niznai's Avatar
You need to give more detail.
There's many options, but do you want them free rotating, do they rotate with the shaft, and so on.
To start you, TA05 had plastic ones, but you need the special alloy shaft, the old Yokomo YR4 had metal ones driven by pins. These rotate with the shaft.
YR4 also came with one way centre pulleys you can convert to rotating on the shaft, but you need to press the one way bearing out.
Check out drift shops. They have pretty much any size and type pulley you want.
niznai is offline
Old 07-18-2015, 08:25 AM
Airwave's Avatar
3Racing, from 13T to 26T or 27T....
Airwave is offline
Old 07-19-2015, 03:09 AM
I'm need to replace my Tamiya 414 center pulleys. The black and chrome 3Racing 15t is what I'm looking for. Just can't seem to find them anywhere.
Old 07-19-2015, 04:41 AM
niznai's Avatar
why not get the proper Tamiya pulleys?
niznai is offline
Old 07-19-2015, 07:01 AM
I changed a lot of stuff. And they no longer line up perfectly. I've customized most of this car
Old 07-19-2015, 07:04 AM
EDWARD2003's Avatar
Google SGE-315bk
That should do the trick.
EDWARD2003 is offline
Old 07-19-2015, 07:15 AM
Originally Posted by EDWARD2003 View Post
Google SGE-315bk
