trinity real time2 tips...
I just picked up a trinity realtime 2 and was wondering if any of you guys could give me some tips to utilize it best. I currently use sanyo 2400's and 1-3300 gp. Thanks--Al
Dont use it on NiMH cells, for NiCads its pretty simple just stick em in there.
NiMH cells dont like to be taken down the way the RT2 does, will shorten your runtime. The fan usually dies in them withing a few months, I just took mine out and its been fine. |
Originally posted by patcollins The fan usually dies in them withing a few months, I just took mine out and its been fine. |
Originally posted by TSR6 Mine is a year + old, still going strong.. |
The best mod you can do to the RT2? Internally wire up the leads of the fans to the battery posts. For the hole where the flyleads come out from put a switch there. Identify +ve and -ve posts (because it is necessary for the DC fan) and you can get rid of that wire for the fan..which always seems to get in the way at the pits!:nod:
Originally posted by dtm The best mod you can do to the RT2? Internally wire up the leads of the fans to the battery posts. For the hole where the flyleads come out from put a switch there. Identify +ve and -ve posts (because it is necessary for the DC fan) and you can get rid of that wire for the fan..which always seems to get in the way at the pits!:nod: Time to hack apart a old Hitec switch, and make some mods. :D Edit - Only problem, sometimes i run it off my power supply... -Troy |
Originally posted by TSR6 Dude! You da man! Time to hack apart a old Hitec switch, and make some mods. :D Edit - Only problem, sometimes i run it off my power supply... -Troy |
Originally posted by dtm haha.........just think..you can carry your RT2 anywhere without that PS line......:D :D I would definately do this mod if i didnt run the RT2 off my P/S. :( -T |
1 Attachment(s)
In true "Blue Peter" style (those from the UK will understand!)......heres one I did earlier!:D
TSR6- did you have to change the fan on your RT2 cause its only a 5v unit...or you have a 5v output from your PS? |
Originally posted by dtm In true "Blue Peter" style (those from the UK will understand!)......heres one I did earlier!:D TSR6- did you have to change the fan on your RT2 cause its only a 5v unit...or you have a 5v output from your PS? -Troy |
Hey tsr6,mine say 2.5 along the base and doesn't have the "discharge device" in between the cells like yours does. It has a synopsys of what do do for each type of cell (nicad/nimh) at each end. I guess mine is the "new and improved". It's probably the same damn thing!!
i crank my power supply up to 15 volts for extra cooling power and its been good for 9 months.
Whats the difference between a Real Time 1 and a Real Time 2 Tray? I have RT1, is it worth upgrading?
The RT 1 has to have the battery oriented in a certian way because it has voltage cutoff diodes (0.6V), the RT 2 doesnt have any voltage cutoffs and takes the cells down to 0V if you leave them in long enough, but this also allows the battery to be put in any way and it will work. This is great for NiCads but is kinda dangerous for some NiMH cells. Sanyos seem to like to be brought down to 0V and even dead shorted sometimes.
My fan died within 3 months and when I took it apart I saw it was only rated for 5V. If you discharge your packs to 5.4V before you put them in the tray it shouldnt get very hot even without the fan. |
Originally posted by dtm The best mod you can do to the RT2? Internally wire up the leads of the fans to the battery posts. For the hole where the flyleads come out from put a switch there. Identify +ve and -ve posts (because it is necessary for the DC fan) and you can get rid of that wire for the fan..which always seems to get in the way at the pits!:nod: and it works great! no more wires in my way again :D |
