Old 10-25-2005, 08:25 PM   #1
Default Installing Power Capacitor
Hi. i got a 8200 novak power capacitor to put in my LRP QC2...
just checking that i install it to the Power tabs on the ESC ? (not the motor tabs)
thanks
Doomah is offline   Reply With Quote
Old 10-25-2005, 10:20 PM   #2
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
yup it goes on the power tabs of your esc. watchout for the polarity. connect the + and - to their respective terminals from the batts.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 10-27-2005, 11:03 AM   #3
Paladin's Avatar
Default Does my Power cap. need replacement?
Do you ever need to replace the Power Capacitator?
And if so, how can you tell that the old one needs replacement?
Paladin is offline   Reply With Quote
Old 10-29-2005, 07:15 PM   #4
jaejw1's Avatar
Send a message via AIM to jaejw1
keep us posted on if it makes a difference,, i know it works very well for mini cars,, but i dont know/still learning if it will make a difference on the 10th scale
vendetta videos.. http://www.rcuniverse.com/forum/m_5684344/tm.htm
motor review
http://www.rcuniverse.com/forum/m_5643067/tm.htm
http://www.rctech.net/forum/micro-mini-scales/156814-vendetta-bl-motor-reviews-pros-cons.html
tire review
http://www.rcuniverse.com/forum/m_6000527/tm.htm
jaejw1 is offline   Reply With Quote
Old 10-29-2005, 09:07 PM   #5
Send a message via ICQ to rcnewb2004
Power capacitors will help the acceleration of your car. No difference in top speed however. my 19T is peeling when it starts up on parking lot with a gear ratio of 1:5 with my power caps. Definately something worth adding to your car.
rcnewb2004 is offline   Reply With Quote
Old 10-30-2005, 05:46 AM   #6
I'm curious too how can I tell is dead or need to replace.
Richard
Clangeddin is offline   Reply With Quote
Old 10-30-2005, 07:53 AM   #7
i just installed it a few days ago. i have a mini, and my times did NOT improve with the installation of the power cap on the LRP Qc2.
Old 10-31-2005, 07:48 AM   #8
Registered User
xrcbuggy's Avatar
Power capacitor only controls the drain load (dropped in voltage) on the battery durring acceleration.
xrcbuggy is offline   Reply With Quote
Old 10-31-2005, 02:23 PM   #9
You can tell if a capacitor is dead by doing this:
(correct me if i am wrong but this is what I do)
1. supply power to the capacitor for a few seconds.
2. disconnect the power
3. use a voltmeter and attach it to the leads of the capacitor, what you should see is a very gradual decrease in the voltage if your capacitor is working properly.
Old 11-01-2005, 05:34 PM   #10
Send a message via AIM to greencactus3
otherwise when it starts to smell REAALLLY bad .... or when it blows its top off then you need to replace it. thankfully its never happened to me.
greencactus3 is offline   Reply With Quote
Power Capacitor simba350 Australia Wanted to Buy 9 06-04-2006 04:53 AM
Power Capacitor ?? T.SATO Electric On-Road 10 04-12-2004 05:18 PM
Power Capacitor T.SATO Rookie Zone 7 04-08-2004 04:49 PM
Power Capacitor johnbull Electric On-Road 31 05-22-2003 08:27 PM
power capacitor - TC3 Brazilian Electric On-Road 11 01-12-2002 08:24 AM
