Xray T4 2016
#379
The inner turnbuckles are adjusted by adding or removing shims under the ball end
#383
#387
Has someone any idea how they do this? Use the LRP 5600 LCG LiPo in mod!
The battery has 275g. Even when I use the LRP 6000 with 295g I have to add 60g to reach the 1350g. Now if using LCG I would have to add 80g! And the left/right balance is way off. I am using REDS motor/ESC combo and alu screws on top like most do. But the electric equipment should not have such a different weight of most other brands. OK tires can have different weight but the balance would be still off!
#389
#390
What does the alum chassis weight vs the carbon? Has to be the best way to add weight low...?
