Like Tree41Likes
HPI RS4 Sport 3
Old 02-11-2019, 07:21 PM
  #1096
Default Will this work?
I built a tiny third channel module holder
NOTE: itís not glued so i still have room to edit it.
Please let me know if aluminum would work better.
Drive safely
RandomUserName is offline
Old 02-12-2019, 08:40 AM
  #1097
Originally Posted by cobrajet View Post
oh sweet jesus cuda!
That body is is a looker, but ever more, I need those foams!!!!!!!!
Glad i dropped in for a look.
Mines been in the box since cannibalizing the electronics to another car. But just dug it out after finding a brand new Flux MMH-4000 motor and EMH-3S speed controller on ebay for less then $85.
I'm still surprised at the lack of part availability. Pulled the Hoonicorn body off to more or less save it from wear and tear since you can only find them on ebay for over $100 and have been running TC bodies with foams, would love to run a Flux body with those wide foams, especially since it's almost impossible to find the wheels and tires for it. Hell, if any one knows of good offset foams that fit something like the spec 5 body that would be great too.
Which castle fan is that?
i wasnt that smart. I wrecked the front of mine
Old 02-17-2019, 07:38 PM
  #1098
I believe the max Ride Height is 7 - 8mm with the shocks.
(taller tires or taller wheels will raise the chassis)
GuyIsDamGood is offline
Old 04-14-2019, 06:35 PM
  #1099
Default TT-01 vs RS4 Sport 3 (March 24th 2019)
I ran another Fastest-Lap Challenge (Tamiya TT-01 vs HPI RS4 Sport 3) (both with some Hop-Ups) - same tires.
TT-01 - - - - - - - - -33.29
-19-T Peak Dynasty
RS4 Sport 3 - - - -34.03
-10.5 Reedy Sonic M3
Old 04-15-2019, 11:14 AM
  #1100
-19-T Peak Dynasty
Either the gearing was wrong on the HPI or the Tamiya driver was way better.
mrreet2001 is offline
Old 04-16-2019, 02:11 AM
  #1101
AW106's Avatar
-19-T Peak Dynasty
While I can see where you're trying to go with it I think you need more controlled elements between the cars, (Motor, ESC, FDR, Body, maybe servo) to give a true comparision of chassis vs chassis rather than build vs build
AW106 is offline
Old 04-21-2019, 06:57 PM
  #1102
Tamiya TT-01
electronics
-ESC: Futaba MC 330CR
-battery: Duratrax 3600mah Ni-MH
-servo: Futaba BLS 451
-m​​​otor: Peak Dynasty (19t)
-body: Tamiya (Nissan R390)
(gearing: pinion - 22 - - - - - spur - 58)
HPI RS4 Sport 3
electronics
-ESC: Hobbywing Xerun 120A, V3.1
-battery: HPI Plasma 2000mah Ni-MH
servo: Futaba 9451
motor: Reedy Sonic M3 10.5
body: Tamiya (Nissan GTR)
(gearing: pinion - 45 - - - - - spur - 100)
same tires on both chassis
(I was running both chassis)
(I recognized the RS4 Sport 3 needs a slight set-up change.
I will run both chassis in the challenge again soon.)
Old Yesterday, 07:22 AM
  #1103
or a better battery.
