Freeing up rc car >
Freeing up rc car
Freeing up rc car
Old 06-26-2015, 12:33 AM
Trader Rating: 23 (100%+)
Default Freeing up rc car
Anybody got any tips to free up belt drive cars? I replace bearings often (every 4 race meets or so) and re oil them every meet. I make sure nothing is binding etc but still have trouble getting my car to spin as freely as some others... and its a problem in stock especially since power is limited...
Zhangesh is offline
Old 06-26-2015, 02:39 AM
EDWARD2003's Avatar
Is the friction quite noticeable? Are the belts too tight?
My experience with my BD7-13' drivetrain.
When ever I screwed down the upper bulkhead to the lower bulkhead the bearings in the cam-holders would squish a little. This was putting pressure on the bearings and was causing unwanted friction. I ended up putting 0.1 mm shims under each screw hole location between the lower and upper bulkhead. This eliminated the unwanted friction and my drivetrain is super free. However, you own a BD7-15'. They might have eliminated this issue.
EDWARD2003 is offline
Old 06-26-2015, 03:39 AM
Roelof's Avatar
Lubricate and clean the belts.
Rubber particles from the track will stick on to the belt making the belt stiffer.
And I always spray the teeth of the belt with a teflon spray what will make the belt run smooth over the pulleys.
Roelof is offline
Old 06-26-2015, 04:43 AM
Ah i've seen people do this before... now i know why. Thanks i'll give it a go
Zhangesh is offline
Old 06-26-2015, 07:43 AM
SagadSetup's Avatar
Trader Rating: 38 (100%+)
What brand of teflon spray do you use sir?
SagadSetup is offline
Old 06-26-2015, 07:57 AM
JimmyMac's Avatar
Are you running the aluminum cams/bearing holders? I ran these on my BD7 2014 and it free'd it up a bit. On my Tamiya's I ran the .1mm shims under the bulkhead caps via Jilles tips. Belt tension also plays a bit roll in free'ness.
JimmyMac is offline
Old 06-26-2015, 02:46 PM
Geezatec's Avatar
I keep my belt dry. just use a brush, maintenance periodically. Too loose on tension small pebbles get into the cogged belt sometime stretching or breaking the belt. I use a military spec on belts, grab the belt, turn it 90deg its tight enough.
Geezatec is offline
Old 06-26-2015, 05:09 PM
Default Flourine
Use Flourine on all the ball ends, pulleys, sus blocks. This really helps free the car up. Below is the link of what I am talking about.
http://www.tqrcracing.com/shop/produ...asp?p_id=10100
VegasGator is offline
Old 06-27-2015, 10:33 AM
Where do u apply the fluorine on the pulleys and suspension blocks?
The holes in the suspension blocks and the teeth of the pulley?
otaku521 is offline
