Old 10-24-2005, 09:46 AM   #1
macnkitty2002's Avatar
Exclamation One-Ways - Do they really help???
I am used to ball diff cars. they say that it is hard to drive a car with a front one-way diff if you are used to ball diffs. are they hard to learn to drive with? and do they really help to improve lap times?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 10-24-2005, 09:55 AM   #2
A one way only propel the car in the forward direction, there is no reaction from the front wheels when you apply brakes.
They are much faster than diffs which turning cannot compared with.
Ultimately they does give better lap times than diffs that for sure.
ah_liang is offline   Reply With Quote
Old 10-24-2005, 10:35 AM   #3
Losi Rock Rey
Old 10-24-2005, 10:54 AM   #4
Send a message via AIM to Deznuts05
They aren't hard to drive with but it depends on where you'er driving it... carpet= ball diffs; asphat= one way...
one ways could be used on carpet however they are very twitchy... if you have a radio that has EXP or ARC throw some Negative Degrees in there to smooth out the reaction time... however if you are looking for that point and shoot action have fun with one ways...
Deznuts05 is offline   Reply With Quote
Old 10-24-2005, 11:08 AM   #5
JonboyGB's Avatar
You just need to drive very smoothly ie, let off the throttle gently rather than abruptly as you might find your car spinning. Also, lay off the brakes - brake hard and you’ll spin.
A one-way will take a little time to get used if you’ve only a diff. As an alternative, have you tried a spool? You get alot of the benefits of a one-way with the stability of a diff.
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 10-24-2005, 12:00 PM   #6
Send a message via AIM to odawg315
i find it depends on the car, my 415 with the oneway had way to much sterring, undrivable. i switched to a spool, and temporeraly set the track record in stock class. my evo iv im faster with a oneway.
odawg315 is offline   Reply With Quote
Old 10-24-2005, 12:14 PM   #7
teamgp's Avatar
Here's a good bit of reading on using a one-way setup with foams on carpet in an XRAY:
http://www.teamxray.com/xforum/viewtopic.php?t=2293
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 10-24-2005, 04:05 PM   #8
ChadCapece's Avatar
For technical asphalt tracks with any tight turns, a spool will usually be faster. It has 200% braking over a diff and has much better acceleration.
A one-way has 0% braking b/c it will spin the car out with a touch of the brakes. Using a one-way takes a different setup then what a diff or spool takes. You'll need softer suspension and less steering.
If your track has alot of chicanes, 180's or tight lanes, you will likely be faster with a spool.
If your track is flowing with smooth turns and long sweepers, then you will likely be faster than a spool.
Front diffs are only fast on carpet with foams. They will not give you the best lap times on asphalt with rubber tires.
ChadCapece is offline   Reply With Quote
Old 10-24-2005, 05:04 PM   #9
i will be racing on asphalt with foams mostly, using rubber tires not that often. i usually only use rubber tires during the summer, foams hook up better when it's cold. i think i will get a spool. even though i don't use brakes hardly at all in my e.p. car, i am not very smooth with the throttle. i prefer to blip the throttle, just like i do with my 1/8 buggy and gas sedan. spool it is!
BTW-does associated make a spool for the TC4?
Losi Rock Rey
Old 10-24-2005, 05:23 PM   #10
loopedeloop's Avatar
I prefer oneway on asphalt myself.
It trains you to be more disciplined coming into corners, is excellent mid corner if you have a blipping throttle style and steers excellent coming out under power.
And in certain situations allows you to duck up the inside on a 180 or hairpin, brake briefly giving a bootleg turn type effect so you can point and shoot for the next corner.You just got to time it right. Just dont use brakes anywhere else cause you will spin
loopedeloop is offline   Reply With Quote
Old 10-24-2005, 05:29 PM   #11
josh69162's Avatar
Send a message via AIM to josh69162
A one way is what I really started learning with. I used my Pro2 up and down the street quite a bit, but only on the race track once. Once I threw my Pro4 on the asphault and got used to the oneway, I don't think I'll ever be able to go back- and if I do, I'll have a nervous breakdown. The feeling of coasting through the turns just makes me feel blazingly fast. And after playing with the ABS on my radio, I've got it to where the car breaks, but not enough to throw the rear end around. Sure it may take a while to get used to, and watching the rear end flip around WILL get frustrating, but if you stick with it, everything else just becomes slow...
-Josh
josh69162 is offline   Reply With Quote
Old 10-24-2005, 06:33 PM   #12
do the spools drive similarly to ball diffs?
Losi Rock Rey
Old 10-24-2005, 06:53 PM   #13
ChadCapece's Avatar
Better in every way.
From my experience, do not use a one-way on asphalt with foams. A spool would rock with foams. If you're using a ball diff right now, a spool will absolutely dominate.
Foams really free up the car through the turns, and if you had a one-way, you would really need to tighten up the car (softer suspension/more roll) Sometimes this can make you feel like you're going faster, when actually you are losing time in the corners.
Old 10-24-2005, 06:54 PM   #14
geeunit1014's Avatar
they push(understeer) more than a ball diff, so you have to tune it out of the chassis but once you do watch the lap times drop . aslo the front tires will wear more and keep an eye on the front drivetrain, spools are hard on the drive components(cvd's, outdrives, ect.)
associated does make a spool part 1704 for the ntc3, but it should work in the tc3/4 as they use same drivetrain, but if it dont be inventive. pass the ca
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-24-2005, 07:09 PM   #15
berger's Avatar
R/C Tech Charter Subscriber
I absolutly love the spool compared to anything else out there, a front differential isnt bad, i like the one-way, but find that on most tracks there is at least 1 corner which requires braking and i just lose too much time there. Spool allows you to drive the car as hard as you can for 5 minutes and its predictable and easier to drive hard than a one-way.
berger is offline   Reply With Quote
one-ways stephen hilton Electric On-Road 2 01-27-2007 09:38 AM
$%^%$^ONE WAYS$%^#$% EDWARD2003 Electric On-Road 10 12-12-2005 05:26 AM
Yokomo One Ways for the TC3 dr_hfuhuhurr R/C Items: For Sale/Trade 14 09-07-2004 10:15 AM
one way going 2 ways? corvettecrazy Onroad Nitro Engine Zone 2 04-01-2004 03:11 PM
TC3: What are the best ways to.... RoadRat Rookie Zone 0 05-19-2003 03:07 PM
