Rubber Tire Compound Question >
Old 06-24-2015, 01:47 AM
Regional Moderator
disaster999's Avatar
Default Rubber Tire Compound Question
What would happen if you use a rubber tire meant for cold weather in the summer? Would it grip like crazy but wear it out faster? Would I get the reverse affect and get less grip? would it spontaneous combust?
disaster999 is offline
Old 06-24-2015, 02:00 AM
chasingthepack's Avatar
you would have great grip for 2 laps then they would overheat leaking the oils and then lose grip and ruin a set of tyres for no gain,tyres are temp rated for a reason
if its for just bashing then yes they would wear quicker but its all down to the surface your running on as to whether or not youll have more grip
chasingthepack is offline
Old 06-24-2015, 09:42 PM
Regional Moderator
Thanks for the reply. Im not sure if leaking oils in RC tires is a thing, but I guess better safe than sorry. Seeing how cheap they were I went ahead and bought a set. If anything, I;ll have something for the winter to run on.
Old 06-25-2015, 11:09 AM
tobyzhang's Avatar
Trader Rating: 15 (100%+)
It doesn't leak oil per say but the oil will start to separate from the rubber. Rough surface will require higher temp tires as well since they will generate more heat.
tobyzhang is offline
Old 06-26-2015, 12:32 AM
Tyres should be selected based on the track surface temperature so sometimes you can get away with 28's or 32's if it is an overcast day in the warmer months.
Here is the temp guide for sorex.
http://www.racing-cars.com/images/pd...temp_giude.pdf
DamianW is offline
