Power Supply
Old 06-21-2015, 06:39 PM
Default Power Supply
I recently purchased a tire truer that required a 12 volt power supply to drive it. i tried to onvert an ATX computer power supply, but my conversion didn't go well.
Can anyone recommend an affordable power supply?
cdraughon is offline
Old 06-21-2015, 07:19 PM
http://www.teameamotorsports.com/ind...product_id=189
avink007 is offline
Old 06-21-2015, 07:46 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
A cheap 3s lipo
wingracer is offline
Old 06-22-2015, 12:17 AM
Geezatec's Avatar
The other gentleman that recommended the p/s that runs I-charger its really under power. That charger is only rated up to 10amps max. I really dont know. To run a truer it is recommened to run 13.8v with 20-30amps constant. I've been using a Pyramid 25k since '93 with no problems. Truer never jammed. And its a Hudy Truer. Expensive p/s but worth it. Pyramid p/s I'd recommend.
Geezatec is offline
Old 06-22-2015, 01:13 AM
Roelof's Avatar
On ebay you can find cheap 12v server PSU's from DELL and HP whic can deliver 47 up to 65 amp.
Roelof is offline
Old 06-22-2015, 02:26 AM
Trader Rating: 23 (100%+)
The EAM power supply is rated at 80A... and thats one of the best value power supplies
Zhangesh is offline
Old 06-22-2015, 02:52 AM
Skiddins's Avatar
What did you do wrong?
Sometimes the 5V and 3.3V need a small load to makew the 12V regulate properly.
Skiddins is offline
Old 06-22-2015, 09:01 AM
This is your best (cheapest) route. I have one myself and it's very simple to setup yourself. The HP DPS 600PB is a server PSU that can be purchased from eBay for $20. There are lots of great tutorials on how to set them up as a power supply. Hope that helps.
TM Ru22311 is offline
