New to F1 Help
Old 06-18-2015, 03:12 PM
Default New to F1 Help
Hey guys I just purchased a good condition used Speed passion SP-1 .. I need to purchase tires and wheels.. What do I need don't want to buy the wrong ones.. I was looking at Sweeps pre mounted pre glued which are listed for use on F104V2 will these work on my car??
If not what do I need to purchase ?
Thanks for any help..
yenko66 is offline
Old 06-18-2015, 03:15 PM
Trader Rating: 31 (100%+)
asphalt or carpet?
shimizu 571/572 combo are very popular!
pat5b is offline
Old 06-18-2015, 03:19 PM
Carpet
yenko66 is offline
Old 06-18-2015, 03:20 PM
rules say rubber tire. 21.5 motors 2s, ROAR approved esc
yenko66 is offline
Old 06-18-2015, 03:23 PM
shimizu 571/572 are very good on Exotek wheel!
pat5b is offline
Old 06-18-2015, 03:30 PM
My concern was about bolt pattern and or wheel fitment mainly.. I have owned some rc cars that use odd ball wheels which where not a class standard and required using only the direct manufactures wheel. What it looks like I'm seeing is that in F1 all the wheels fit any of the chassis out there.. is that correct ? Like in 1/10 TC racing all are built as 12mm hub wheels and fit any 1/10 TC car..
yenko66 is offline
Old 06-18-2015, 03:49 PM
some formula 1 have not the same offset wheel as the other, like hpi and 3racing fgx etc!
pat5b is offline
Old 06-18-2015, 03:59 PM
maybe more than all your answers here!
http://www.rctech.net/forum/electric...1-car-sp1.html
pat5b is offline
Old 06-18-2015, 04:06 PM
The SP-1 has adjustable wheel track so running the Exotek wheels are not needed to get the width. The Exotek wheels are great but the extra off-set may make the car too wide for his rules.
Most of the F1 cars on the market now use the same mounting pattern as the Tamiya F104. There are a few exceptions like the 3Racing FGX but not many.
InspGadgt is offline
Old 06-18-2015, 05:28 PM
R/C Tech Elite Member
JayL's Avatar
You want Tamiya F104 Foam wheels, part 51378 are the black version
and Pit Shimizu F104 Rubber Tires
for carpet you will probably want Pit 575/573 maybe 571 fronts
tires:
http://www.tqrcracing.com/shop/produ...no=1&o_pg_no=1
JayL is offline
Old 06-18-2015, 06:08 PM
Find out what they run at your local track first, many places run a "spec" combo which usually ends up being the Tamiya #1031(soft fr) and #1032(hard rear), aka Pit 571/572.
nwagner is offline
