My brand-new Tamiya FF04 FWD touring car >
Old 06-16-2015, 11:59 AM
fyrstormer's Avatar
Default My brand-new Tamiya FF04 FWD touring car
Somewhere, deep down, you knew my foray into touring cars wouldn't involve doing the same thing everyone else is doing.
Obviously this vehicle is nowhere near done, but I wanted to show off the chassis before it gets clogged with wires and electronics. There's a beautiful simplicity to having absolutely all of the action happening near the front axle, with the rear axle completely un-cluttered. RWD vehicles are almost like that, but not quite, because the steering still has to be in the front.
I look forward to seeing how this thing drives outside of my imagination.
fyrstormer is offline
Old 06-16-2015, 12:14 PM
patorz31's Avatar
You will like it. I just got into FWD TC too. The way I describe it to my friends is that it drives like a Big Tamiya M05 that drives straight. What I mean by that is that they are a hoot to drive and race. They are fast and cheaper then 4WD. Also when you beat a 4wd the look you see on the other guys faces is awesome.
patorz31 is offline
Old 06-16-2015, 01:00 PM
SteveM's Avatar
Trader Rating: 160 (100%+)
Looks great.
SteveM is offline
Old 06-16-2015, 01:09 PM
silentboost's Avatar
Trader Rating: 64 (98%+)
i absolutely love the Tamiya FF lineup, had almost every one of them (except the FF02), they got better and better with handling.
Im now nursing a new in box ff04 evo, trying to build up the courage to build it..
silentboost is offline
Old 06-16-2015, 01:10 PM
bought these two together:
Old 06-16-2015, 05:17 PM
fyrstormer's Avatar
Belt-drive on an offroad vehicle? Isn't that asking for trouble?
Old 06-16-2015, 05:18 PM
fyrstormer's Avatar
No courage needed. Just dive in and build it. I barely even needed to trim any flashing from the kit, everything was molded so cleanly.
I originally wanted an FF03 Evo, but I suppose if the FF04 has better handling, then I'll make my peace with the "boring" conventional front-shock layout.
Old 06-16-2015, 05:19 PM
fyrstormer's Avatar
Do the M05's not drive straight? I find that surprising for a kit from a brand as well-respected as Tamiya.
Old 06-16-2015, 05:50 PM
fyrstormer's Avatar
Anyway, I thought it was interesting that the FF series is actually a simplified version of the XV01. I've never seen a front-motor-4WD RC before. How do they handle compared to mid-motor cars?
Old 06-16-2015, 10:05 PM
patorz31's Avatar
Tamiya had a front motor touring car years ago. The TA03 series. David jun won a roar national title with one. It was there first serious racing tc. They easy to drive with the motors and tires of the time.
The tamiya mini's have a terrible amount of slop in the suspension and steering. They wonder a bit down the straight. Funny thing is you take out the slop they handle like crap, they work better with it.
patorz31 is offline
Old 06-16-2015, 11:41 PM
fyrstormer's Avatar
On my Losi and Associated minis, I just toed-in or toed-out the wheels as appropriate so the slop would be held in-check by the wheels putting tension on the suspension linkages.
Real cars have rubber bushings in their suspensions, so their suspensions can have some freedom to flex without rattling around, so in a way real cars have "slop" as well, it's just buffered so the driver doesn't notice it. Perhaps instead of shimming the slop on the M-chassis cars, O-rings would work better.
Old 06-17-2015, 05:43 AM
tc3team's Avatar
Foams too, contact tyres if I am not mistaken
Nice car.
I used to race the Yokomo YRF2 many, many years ago. I liked how light 2wd cars are and their simplicity.
Unfortunately though on lower grip tracks it obviously took a while for them to get off the line compared to 4wd cars.
I had an FF01 Tamiya before that, but obviously it wasn't competitive enough to be raced against better stuff.
tc3team is offline
Old 06-17-2015, 11:26 AM
fyrstormer's Avatar
Xceed RC tires, actually. Nice and sticky. We'll see how well they actually work.
I decided to go with foam tires on this one to maximize grip on the front axle. If it turns out that it has plenty of grip, then maybe I'll switch back to rubber tires, so I won't have to worry about chunking them.
Old 06-18-2015, 03:36 AM
tc3team's Avatar
Imo you made a good choice to start with and worth experimenting. You will need a bit more grip to make up for the 2wd, especially from launch.
tc3team is offline
Old 06-19-2015, 12:00 AM
fyrstormer's Avatar
Low-profile steering servo and radio receiver showed up today. Got them installed, then swung by the hobby shop to pick up a Velcro strap to hold the battery in-place. (supposedly I'm supposed to use some kind of special tape that has to be replaced every few uses...no thanks.) I put the Velcro strap on the chassis, then sliced the strip of one-sided foam tape that came with the kit into two thinner strips, and stuck them on the chassis on either side of the Velcro strap to give the battery a grippy surface to sit on.
All I need is the ESC to complete the chassis, and then I can start agonizing over which body shell to use.
