What are the best adjustments on a tourer going from medium grip to super high grip ? >
Old 06-09-2015, 07:10 PM
TPR 1's Avatar
Trader Rating: 26 (100%+)
Default What are the best adjustments on a tourer going from medium grip to super high grip ?
Hey guys , going to run AOC in Australia in a couple weeks and have never run on
super high grip.
The track is indoor asphalt and will have extremely high grip during the event what adjustments would be recommended to slow the reaction of the car down ,
stop traction rolling etc? (event has a controlled tyre)
TPR 1 is offline
Old 06-09-2015, 07:53 PM
Sorta depends on the issues you are facing due to the grip being high.
For Traction Roll
- Ride Height (lower)
- Roll Bar Balance (front harder, rear softer)
-Roll Centre (front higher, rear lower)
For a smooth high grip track you can generally take advantage of stiffer springs. But there is a limit to that as the car is hopefully only 10-20grams over the limit
cplus is offline
Old 06-09-2015, 09:48 PM
mschumi101's Avatar
Trader Rating: 30 (100%+)
The more the grip comes up the more I like to run long upper links. It takes away some grip, but can make the car a little more aggressive.
mschumi101 is offline
Old 06-10-2015, 04:15 AM
Less front camber, softer springs, glue sidewall of front tires
anr211 is offline
Old 06-10-2015, 04:49 AM
you can also widen the front to prevent traction roll and smooth out the steering
Duzgit is offline
Old 06-10-2015, 05:43 AM
cplus is offline
Old 06-11-2015, 03:04 AM
xevias's Avatar
Originally Posted by cplus View Post
Yep. A softer spring allows the car to roll a bit instead of digging into the track surface, causing the tire to flex more, ultimately causing a traction roll.
The opposite is sometimes true when you don't have enough traction, by using harder springs to get the tires to dig in more.
It is weird on paper, but sometimes works on the track.
xevias is offline
Old 06-11-2015, 03:10 AM
EDWARD2003's Avatar
What car are you running?
Check out the RC Crew Chief thread and ask your question there. Bob will be more than happy to help you out with high traction setup scenarios.
EDWARD2003 is offline
Old 06-11-2015, 03:35 AM
TPR 1's Avatar
Xray T4 15
ok kool ill check it out.
TPR 1 is offline
Old 06-11-2015, 04:02 AM
Its really going to blow your mind if I tell you that adding droop can help with traction rolls too.
anr211 is offline
Old 06-11-2015, 06:26 AM
b20btec's Avatar
I believe you. On high bite carpet, I had to add more droop up front to prevent the car from catapulting. There is a fine line on how much droop to add and when this is proper to implement.
b20btec is offline
