VBC Lightning10 LM 1/10 World Endurance Kit >
Old 06-08-2015, 01:45 PM
angrymelon's Avatar
Default VBC Lightning10 LM 1/10 World Endurance Kit
From vbcracing.com:
Welcome the world of exciting endurance racing! The New VBC Racing Lightning 10 LM is base on the successful Lightning series pan car platform. With simple, durable design yet highly tunable to suit different track condition. Kit includes highly detailed body, BSR racing spec 1/10 pan car foam tires. A true scale racer out of the box.
Features:
- Lightweight 7075 aluminum alloy parts
- Durable Fiberglass chassis and suspension components
- Strong carbon fiber rear main shaft
- Accept normal 1/10 pan car tires
- Adjustable camber, caster, toe in/out for maximum performance
- Adjustable reactive caster to increase front grip yet improve stability
- Oil filled damper for adjustable damping, rebound, optional springs available separately
- Aluminum Alloy 7075 rear motor mount and bulkhead to increase stability and durability
- Full adjustable ride height
- Lightweight 7075 aluminum alloy drive hubs
- Impact resistance Fiberglass bumper
- Full line of tuning options available to suit different tracks
Kit includes realistic world endurance body, and BSR Racing foam tires
angrymelon is offline
Old 06-08-2015, 01:48 PM
pphaneuf's Avatar
I wonder what's the body... Looks like the Speed Passion LM-A, but the wheelbase would be slightly wrong?
pphaneuf is offline
Old 06-08-2015, 02:48 PM
patorz31's Avatar
Rumour has it from a few sources, the guys that own VBC have a very large interest in Speed passion.
patorz31 is offline
Old 06-08-2015, 03:03 PM
angrymelon's Avatar
It does appear to be the same Audi body from the Speed Passion LM-1. The front suspension is different on the Lightning10 LM to make it have the same wheelbase (275-280mm) of the LM-1.
Old 06-08-2015, 04:10 PM
will the body be a 200mm body and will it be available seperate?
BullFrog is offline
Old 06-09-2015, 03:49 AM
pphaneuf's Avatar
Really? As I recall, that would make it too long for the BRCA GT10 class (which is the same as WGT, except for more bodies allowed, including some of that style, with split wings)... And possibly WGT too?
pphaneuf is offline
Old 06-09-2015, 02:51 PM
It already is
http://shop.speedpowerrc.com/1-10-lm...ans-bodyshell/
terry.sc is offline
Old 06-18-2015, 09:35 PM
Rabbit0317's Avatar
Couldn't take it anymore and ordered mine today. Now I have to sit impatiently and wait for it to arrive.
Rabbit0317 is offline
Old 06-21-2015, 10:51 PM
Richards Racing's Avatar
In Australia we run Rubber not foams so I have ordered a F1 rear Axle assembly to slot in, kit arrived loved the fact that it came with Body & Foams BSR by the looks great quality. Will not be assembling till after I get back from Europe in September.
Richards Racing is offline
Old 07-16-2015, 03:14 AM
pphaneuf's Avatar
Anyone received the kits? What's the wheelbase like? Similar to "regular" 200mm pan cars (in the 250mm to 263mm range), or similar to the Speedpassion LM-1 (275mm to 280mm)?
pphaneuf is offline
Old 07-16-2015, 03:16 AM
pphaneuf's Avatar
Also, for people in the UK and Europe, it's available here for €249.90 (about 175), and should be no duty to the UK (and reasonable shipping):
http://www.sven-rudig.com/shop2/inde...g=en&info=4644
pphaneuf is offline
Old 07-16-2015, 07:10 AM
pphaneuf's Avatar
I found my answer in the manual... It can be set up for 269mm or 275mm.
Looks like the only different part is the front suspension front plate, maybe fitting the one from the Lightning10 would bring the wheelbase within the rules for ROAR WGT and BRCA GT10?
But then the body wouldn't fit well, and it brings back the cost almost to the same level as other WGT/GT10 cars (still get a free set of BSR tires, though!)...
pphaneuf is offline
Old 08-17-2015, 02:58 PM
angrymelon's Avatar
Finally got one built. This thing is the deal of the century. Lots of aluminum and carbon axle goodness!
Old 08-18-2015, 05:09 AM
pphaneuf's Avatar
That's a lot of Ackermann in your steering there! Is it possible to move the servo forward?
pphaneuf is offline
Old 08-18-2015, 09:44 AM
angrymelon's Avatar
Those aren't the actual servo mount locations. I just put them there to display this roller. The servo would be off to the side and the steering links further forward.
