Rotor difference >
Rotor difference
Rotor difference
Old 06-01-2015, 08:55 PM
Default Rotor difference
On speed passion website they have different rotors for different turns. The rotor I need is made for 3.0t to 8.5 but does anyone know if I can use the one that is made for 9.5t to 21.5t. They look the same but don't want to buy it unless I'm sure they will fit.
Tc460mph is offline
Old 06-02-2015, 03:06 PM
Geezatec's Avatar
Rotors look the same. Difference is the magnetism, they are permanent magnets. What kills them is heat.
Geezatec is offline
Old 06-02-2015, 06:54 PM
Oh ok so I shouldn't go with the higher turn rotors. Why would the magnetism be different for?
Tc460mph is offline
Old 06-02-2015, 10:16 PM
Geezatec's Avatar
Layman terms. Without magnetism motors do not work. Brushed motor, permanent magnet is the can, Armature the winding, brushes(commutator) contact the armature. The opposite with Brushless. Armature the can, permanent magnet the Rotor. No Brushes.
Number of turns of motor are winding of gauge wire. lower the gauge more reactive of magnetism it develops. higher gauge less reactive. More voltage the poles from N to S the greater the magnetism.
Brushless motor does not physically brushes in contact with a commutator or armature. Brushless done by Magnetism. Magnetism is a phenomenon in electronics. Field it create from voltage creates the permanent magnet to react.
Layman term instead of the X,Y Z in mathematic or scientific garcon.
Geezatec is offline
