Old 10-20-2005, 10:08 AM   #1
thecrow2k's Avatar
Default Rubber Tires On Carpet
We run on carpet at our track, looking on the weeb I found I could buy a full sorex tyre set for $30, I was looking as my foams tend to be pretty much useless after 45runs in tamiya class, I understand rubbers would get less grip and I was looking at the sorex 24r tires, how many runs do you think I could get out of them.
thecrow2k is offline   Reply With Quote
Old 10-20-2005, 12:26 PM   #2
thecrow2k's Avatar
Anyone?
Old 10-20-2005, 12:31 PM   #3
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Originally Posted by thecrow2k
Anyone?
depend on how thick is your insert..
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-20-2005, 02:06 PM   #4
thecrow2k's Avatar
The team sorex medium or firm insert
Old 10-20-2005, 06:06 PM   #5
Joel Lagace's Avatar
Sorex 24s with hpi blue front and hpi green rear inserts is what i used to run in rubber stock sedan. Great grip fairly good lifespan.
But your going from foam to rubber? If your racing against foam cars you will be at a huge disadvantage. LEss traction and much more rotating mass,
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-20-2005, 07:42 PM   #6
Stevietd14's Avatar
Send a message via AIM to Stevietd14 Send a message via Yahoo to Stevietd14
At our track a set(4) of Jaco's runs $30 and a set of Twister's runs at $24.If foam tires are cheaper,hook up a lot better, and get a lifespan close to rubber, I would stick with foams.
Steve
Stevietd14 is offline   Reply With Quote
Best Rubber Tires for Carpet? punkracer24 Electric On-Road 5 08-19-2007 11:23 AM
rubber tires on carpet trilerian Electric On-Road 6 09-29-2006 04:36 AM
Rubber tires on carpet? TC3er Electric On-Road 22 03-10-2004 09:06 PM
Best rubber tires for carpet wdm80 Electric On-Road 44 02-20-2004 04:38 PM
Rubber tires on carpet? Speedie Electric On-Road 20 11-05-2003 04:52 PM
