Quantum Comp/Nosram/TRF ESC
Quantum Comp/Nosram/TRF ESC/Futaba MC800
Can anyone give an inside track to the similarities/differences of these ESCs. They all look the same on the outside but what about other things like internal resistance, software, current, etc.
As far as I know the Quantum and the Nosram are the same ESC's. The Nosram is just a Quantum 'rebadged'.
And the TRF ESC is a KO Propo Item.....
Exact specs I'd have to check...
pp3: the Nosram, Quantum and Futaba barnds all have the same "quantum type" speedo - same specs, functions, just different packaging. as for the TRF, i havn't seen pics or write ups on it so i can't say. (laro tayo sabado sa capitol! Chameloen spec race!)
rccarracer: what KO esc is it patterned after? is it like a repackaged KO -VFS? coz if so, thats an awsome speedo. that variable drive frequency feature is amazing! i heard the KO was one of the most used esc's in the recent All Jap Nats.
ROBORAT: and there is also the GM SX9....any feedback on this new one????
So it is safe to assume that the ESCs I mentioned are all the same underneath their different casings???
Quantum, Nosram and Futaba are the same speedo.
Tamiya's TRF is a rebadged KO VFS.
GM SX9 is different.
I'd like to pick up a GM V12xs. I hear there good. Any comments on them???
pp3: yup, they're all the same. i dont know much about the GM speedos though but if what rccarracer is true, the TRF should be a good buy since its a repackaged KO VFS-2000. to give you an idea, this speedo lets you fine tune the drive frequency of your throttle into 32 different steps. think of like like you can have a diff frequancies at 1/4, half, 3/4, and full throttle. probably the best and most innovative feature ive seen among the current lot of speedos. and i believe KO has pattented the VFS funtion so you wont see it elswhere .... unless they agree to tie ups to repackage it .... like with Futaba. oh, and durability is something i cant comment on either.
? on what is this esc. KO VFS 2000... all about.?
this KO VFS 2000... sounds really awesome. but what all does it do and can you program it ? explain this to me . please ... i am looking for a esc.
thanks....
thanks....
Re: ? on what is this esc. KO VFS 2000... all about.?
thanks....
thanks....
KO VIS is the most adjustable ESC, no doubt. On the other hand, you would have to remember, the more function it has (which on KO, requires additional hardware), the more works need to be done. Would you rather play and enjoy, OR ending up setting ESC (beside fine tune your car and motor) all day long just to get the right feel for the current layout? And yes, when the layout changed, you would need to find tuning them again.
Does it have default setting programmed from the factory? if so, you would end up feel guilty for not using the most of its features.
In case you have a lot of time to explore, keyence Vzero Xtreme 2002 is a good ESC to experiment with, at least is less complicated the KO VIS and require NO additional hardware to change its additional function. I used it myself but I never play with its adjustable function since I prefer to play while practicing.
Either LRP (Furtaba/Nosram), GM, Keyence, KO VIS are consider high-end ESCs looking from its specs.
I tend to agree but I would be interested to know How many racers actually exploit all the features of their respective speedo's? I mean when was the last time the car was a little off beam and you went and played with the speedo and the handling problems went away?
Surley there's a case for a speedo with less features as its one less thing to worry about if you have it set right or not?? Especially now that radio's have become so much more adjustable than a basic Futaba unit. Aren't we being seduced into buying ever more expensive speedo's because they are so feature rich, when a more basic unit without the 'Turbo Nutter' feature would do the job just as well??
I can undersatnd it if you are running a 7 or 8 turn motor with top of the range cells but for club racing something more modest must surely be ok.
Any thoughts??
Any thoughts??
I agree - the only functions I could imagine using are a drag brake and a "turbo" start function.
Programming the drive frequency at different points of the throttle curve is something I don't think I could get my head around - it's hard enough ssetting up the mechanical side of the car.
Anyway, my radio has a throttle curve function, so if I wanted to milden out the throttle response, that's a lot easier to do from the handset.
The question is: Should your ESC do the work or your trigger finger?
I got the LRP v7.1, and I'm using the "turbo start" and I've disabled the auto-brake since I'm running one-ways. The first couple of practises with the 7.1, I experimented with the current limiter, which both can be traditionally limited or can be limited for a very short time (variable too). I ended up with no limitations at all. Okay, maybe, someday, if I come to a slippery track and I aint got the right tires.... But the next time I come to that track, I got the right tires.
ESC adjustments
me too!!! i am using a Quantum Competition and the only thing i change is the punch control depending on the motor and/or track conditions.
Sorry - I must confess to using the current limiter as well - but I don't use it as a "slipper substitute", I just set it so i don't notice it, hoping that it's saving a little bit of battery energy.
