Old 10-26-2005, 04:17 PM   #16
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
no, connect the 110V to power, the charger should come one.
then connect the 16x5 connector that you would normally connect to a power supply to the small round red & black connections on the rear of the unit.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 10-26-2005, 04:33 PM   #17
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
did exactly that, u get nothing. Ive since found out on another forum its a known issue. its to do with the failsafe in the powersupply. the jacks work fine as 12v input for the original charger, but when using 110v, and attaching another peice, the powerrsupply shuts down the banana jacks. only solution is to bypass the failsafe as mentioned above. this voids the warranty, but ive heard its the ONLY solution. one disgruntled buyer actually posted this on integy's forum and theres no response from integy themselves.... to me thats poor business. you find someone with a problem with your product, you either point out wats wrong or take responsibility... and that post was from 2004...... guess ill have to get it working myself ...
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 10-26-2005, 05:24 PM   #18
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Can anyone give a more detailed explanation on how to do this?
EricO3 is offline   Reply With Quote
Old 10-26-2005, 07:42 PM   #19
Tres's Avatar
hmmm, not sure, I used the 12v output on my 16x9 & 16x9v6....
Tre's
www.tnt-fx.com
Old 10-27-2005, 07:46 AM   #20
axle182's Avatar
from what i have read, the output on the 16x9v6 doesnt work unless your trying to power up something like a LED or something tiny like that. The failsafe disconnects the power to the banana plugs as soon as a draw is noticed. Again this is from a forum on the integy website, and no response from integy themselves.
I did the fix last night. takes two seconds but does void your warranty. Take off the top of the case, you'll see two circuit boards. the one at the front is the powersupply, and the one at the rear, with the massive heatsink is the charger board. You'll see two red and two black wires coming from the front circuit board to the rear one. You can also follow where the banana plugs are soldered onto the rear board. cut these wires, and solder them to the same connection as the two red and two black wires from the powersupply. Took me two seconds to complete, and worked fine last night at racing. I may make a change tho, im going to put an inline fuse in the Banana plug red wire, to ensure it doesnt short for whatever reason. But for now, im happy again with my charger. I ran my 16x5v6b off the 16x9v6 and worked perfectly. Im going to put it to the test soon, Im going to make a power board, and run my dyno, lathe and 16x5v6b off it. They say its a switching powersupply, so it should be fine if its over loaded, should just shut down. But hey.... i beleived i was able to connect another charger to the 16x9v6.....
Aaron "AJ" Freind
Old 10-27-2005, 12:09 PM   #21
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
EricO I have a 16X9 v6.0 and I use the built in power supply to power a Pulsar and a Intellipeak. I solders a pair of Corally blugs to the pulsar and the connected it to the back of the X9. I had the same problem with the Power supply not working, but I foundout that all I had to do was hookup the negative to the PS and then rub the pos around the plug on the back of the charger until it came on it takes upto 5 seconds but make sure that the 16X9 is on first. If U connect the other charger to the X9 first and then plug in the X9 it won't power the second charger. I've been doing this for about 2 years and have had no problems with the X9, the puwer supply or any charger I connect to it. I'm not sure if U can do this but I am able to connect 2 chargers to my X9 and have all 3 charge at 5amps with no problems as of yet but to be safe I wouldn't go above 13amps total for all.
Hope this helps.
Bob
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
Old 10-27-2005, 04:25 PM   #22
axle182's Avatar
Well finally got a reply from Integy regarding the problem, I was told that the charger wasnt designed to have 12v output!! I was told the banana plugs are only for 12v input only when using a car battery etc. I quickly replied how in the description of the charger, it states that the powersupply in the 16x9 is powerful enough to power your indi dyno, lathe etc. I asked how can one do this, if your powersupply in your charger wasnt designed to power anything else, and doesnt come with anyway to connect the other equipment!
It was also mentioned that quote "Some racers managed to bypass the internal circuit protection and hookup a 2nd charger directly to the back. Others have rewired the unit to access the 14A power supply"
Hmmm....
at any rate, ive got it working the way i want.
On another note, are the batteries you charge with this charger coming off hot? Mine are continuously coming off almost too hot to touch at a charge at 5.5 or 6 amps (GP3300).
Aaron "AJ" Freind
Old 10-27-2005, 04:34 PM   #23
rc-zombies's Avatar
even on the smaller 16x5V6..comes out hot..
set your voltage threashold to 3mv.
I put my pack on a fan when charging.
hopefully the new 16x512 and 16x912 will change all that when it gets released w/3 stage charging and temp probe.
Old 02-10-2006, 02:31 PM   #24
Casper's Avatar
Trader Rating: 34 (100%+)
Anybody seen a picture of the new 16X512? I am hoping it is the same size as the 16X5 and retains all the other features!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-10-2006, 03:10 PM   #25
EricO3's Avatar
So you cut the banana plug wire inside the charger off of the charger circuit board , and solder them onto the solder joints were the two red/black wire are soldered onto the charging circuit board from the power supply?
-Eric
Old 02-10-2006, 03:23 PM   #26
Tres's Avatar
Not sure if this is it or not....
But, it's one of the new models...
Old 02-10-2006, 03:26 PM   #27
rc-zombies's Avatar
That's the 16X405D2.
Old 02-10-2006, 03:32 PM   #28
Tres's Avatar
Nope, I have a 405D2, it's looks like this:
Old 02-10-2006, 03:37 PM   #29
rc-zombies's Avatar
you are right..my booboo..
indeed that could be the new 512...that I'm patiently waiting for...
Old 02-20-2006, 02:28 PM   #30
Casper's Avatar
I was thinking it should be much smaller then that due it being DC only. I am wondering if it will have motor break in features and stuff. I love my 16X5V6 chargers but having step and thermal cutoff features would make them perfect! Is there and indi electronics site anyone know of that might have any info on these new chargers? I am not sure I can wait until late april! LOL
((Indi 16x9V6 w/builtin power supply, Indi Dyno V2)) F. Mendoza R/C Items: For Sale/Trade 15 10-29-2007 08:34 PM
INDI 16x9v6 Question SOuthernFRIED Electric On-Road 2 07-19-2004 06:17 AM
Indi 16X9v6 Charger birdy233 R/C Items: For Sale/Trade 2 06-06-2004 08:00 AM
INDI 16X9v6 charger Silvercomet Electric On-Road 2 03-11-2004 09:24 PM
Eagle Racing/INDI 16X9v6 1-10 Cells AC/DC Computerized Charger? bruisedwillis Electric On-Road 20 11-28-2003 10:54 AM
