Old 10-19-2005, 06:02 PM   #1
Default stock motor tips ?
at the last club race i went to i was out motored the whole day by every one
i just cut the com and changed the brushes but i cant get any more power?
i have been runing bianary stock 4 mag moters because i gent get a monster stock to put out power for long il have to rebuild it every run?
tips ANYONE .
cain921 is offline   Reply With Quote
Old 10-19-2005, 07:00 PM   #2
Drew_Cat's Avatar
tips ANYONE .
http://www.rccars.com/forums/forumdi...?s=&forumid=19
Items for sale:
TURBO GFX>>>> http://www.rctech.net/forum/showthread.php?p=4329165#post4329165
Tekin Battery Nurse >>>> http://www.rctech.net/forum/showthread.php?p=4329173#post4329173
Thanks for looking
Drew_Cat is offline   Reply With Quote
Old 10-19-2005, 07:26 PM   #3
TeamPink91's Avatar
Send a message via AIM to TeamPink91
I like this one...
http://www.motortuningsecrets.com
TeamPink91 is offline   Reply With Quote
Old 10-19-2005, 08:01 PM   #4
schmelme's Avatar
Cut with a good lathe, new 767's you should be ball park as long as the motor isnt cooked. You sure its not your batterys?
schmelme is offline   Reply With Quote
Old 10-19-2005, 08:52 PM   #5
Remember that others might not be outmotoring you, but could be driving smoother as well, or have better car setups. I have not been driving indoor carpet for very long, but have realized that keeping your momentum is just as important as having decent motors and batteries. If you need to let off for every turn on the layout, then you will probably be slow. Someone else that is holding their speed through a smooth line will appear to have a faster motor, when in reality that may not be the case. It might help to fiddle around with setups more.
TPJ International
071crazy is offline   Reply With Quote
Old 10-19-2005, 11:04 PM   #6
thanks for the links guys
ima try some new tricks
and by they way im sure i was being out motored
but driving smother does help in corners
but bieng laped on the strait doesent
Old 10-19-2005, 11:15 PM   #7
JimmyMac's Avatar
Are you sure it's not your gearing? Or batteries like what was mentioned earlier? What class are you running? And what's your gearing and track size?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-19-2005, 11:20 PM   #8
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
this is what you need!
http://www.bmiracing.com/products.htm
Old 10-20-2005, 02:58 AM   #9
Send a message via AIM to R/C Anonymous
batteries make a big difference in motor performance
R/C Anonymous is offline   Reply With Quote
Old 10-20-2005, 05:08 AM   #10
geeunit1014's Avatar
he's right, i knocked .2 off my lap just by changing packs. or was it beacuase i put on a futaba t-shirt...
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-20-2005, 05:55 AM   #11
IN10CT's Avatar
yeh i also got faster by changing batteries and shirts
IN10CT is offline   Reply With Quote
Old 10-20-2005, 06:47 AM   #12
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
No the changing of shirts just made you smell better and by doing so messed up everyone's concentration....
Just don't put on alot of cologne cause mixed with paragon...people could vomit..>....>.>..>.>.> LOL.....
Just buy your horsepower Cain921
www.teameamotorsports.com Best monsters and IB cells out there....Plus a really nice guy and racer so he can help if you call him.
Cain also gearing is 90% of setup on the motor...
Cut the comm put in some F brushes.....(another plug for EA cause he carries them). Break the motor in at 2Volts for 400-500 secs....install and drive fast.
I don't know your track but here is a little helpful hint....
If your motor is slow on the strait (i.e. it gets up to full speed at 1/3 of the strait) than you need to got up a tooth or three....
If you are transitioning slow through the technical parts than drop a tooth.
You should gear so that your motor winds out about 2/3 of the strait...
That way you keep your tech sections competative while still keeping up on the strait...
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-20-2005, 08:36 AM   #13
jaejw1's Avatar
Send a message via AIM to jaejw1
what about brush combinations,,, using a hard high silver brush on positive and a softer and also tweaked(cut/slotted/drilled) brush on the negative along with a heavy spring on positive and a softer spring on negative.. would this do anything..
im also trying to find out why in my stock racing class the number 1 guy was 4 seconds fater then me overall i came in second.
my set up
p2k2
90/20,,, planning on using aluminum pinion
xxx lemans/trinity purple spring/positive
trinity 4504/trinity green spring/negative
fresh cut comm
vendetta videos.. http://www.rcuniverse.com/forum/m_5684344/tm.htm
motor review
http://www.rcuniverse.com/forum/m_5643067/tm.htm
http://www.rctech.net/forum/micro-mini-scales/156814-vendetta-bl-motor-reviews-pros-cons.html
tire review
http://www.rcuniverse.com/forum/m_6000527/tm.htm
jaejw1 is offline   Reply With Quote
Old 10-20-2005, 08:59 AM   #14
dstyles's Avatar
he most likely can hold his line better than you.
dstyles is offline   Reply With Quote
Old 10-20-2005, 12:15 PM   #15
jaejw1's Avatar
negative,, his car was faster,,, ,, but i will say it was a combination of both..
motor review
tire review
Tamiya TA04 Stock Tips Pat Electric On-Road 17 09-21-2010 09:23 PM
Best Tips From Best Stock Racer- Clark Smith Zaner24 Electric On-Road 11 11-05-2007 09:25 PM
Stock Racing tips? entilza Electric Off-Road 28 10-02-2007 01:55 PM
TIPS FOR STOCK MOTORS BEASTY200 Electric On-Road 1 01-21-2007 03:36 PM
NEW Stock Motor break-in tips... gcooper Electric On-Road 1 07-22-2004 03:59 AM
