hpi rs4 rally
#16
Yah, the HT parking lot races
I'm amused you say aluminum (I have some super thin stuff) would be way heavy :P But I will look into that vinyl stuff. I fig'd that the aluminum would be best because the chassis has cutouts and with anything stick-on then crud would just build up in those cutouts. I COULD put a bit of baby powder in those parts to unsticky them. Yah, that'd work
Still waiting on my servo mount blocks
In this case, take that thin aluminum and weigh it against the vinyl. The vinyl will be lighter (probably thicker too).
You're right about the cut outs in the chassis. That's why, when you put the vinyl on, you'll go back with a hobby knife and cut out those areas that are not directly stuck to the chassis. Basically the shape of the vinyl will be an exact duplicate of the shape of the stock chassis.
#17
I thought about cutting out the screw holes, but not the chassis holes, haha
I've been busy so have been lagging on this
Some updates: due to the Castle motor hitting the chassis (and being an old, discontinued model I can't bring myself to trim the chassis to make room) got a new 28T pinion. Got a servo mount, but need 2 so had to order a second one. That mount is my hold up right now. Was actually thinking of using the mill at work to machine one out of aluminum
#18
Duh
#19
It's finished! Took it out on its maiden voyage tonight
Just need to adjust the steering, get stiffer shocks, wheels/tires, and that plastic coating stuff. This Sunday will be my first race
I'll get a few pics up later
EDIT:
EDIT:
#20
Was not able to race Sunday because I had to go to work. Almost got away with it too, oh well. I wasn't 100% ready because my wheels/ tires weren't ready
Anyway! It's pretty much race ready. New 29mm springs(HPI 3868),from the stock 40mm, which dropped the front 11mm and the rear 9mm. HPI Mesh Wheels #3711(http://www.hpiracing.com/piw4.php?part=3711) and painted them white (I now see that #3710 are white, lol) with some Associated street tires
Did some finishing bodywork tonight since the front tires, when turning, would scrape, so they shouldn't scrape anymore
So that's about it. I'm not sure how fast it goes, but it hauls
Took it to my HobbyTown so the owner could see it (he's been drooling over it) and was amazed at how smooth it ran and such. He loved it
I'll try and get some pics later. It's starting to get dark, so will get some good pics of it when it's lighter out
