RIDE HEIGHT
Im trying to ADJ my ride height with the screws and shock springs,the problem i get the rite height i want but the shock is compressed and the no rebound.
It sounds like your shocks are too long. Perhaps you could get more out of them by using the outer most mounting holes, or maybe you have to put more limiters inside the shocks. Check what offset cups are on them. Maybe you could adjust them in with the eyelets a bit, or look into slightly shorter shock shafts.
Would it my springs are to soft(grey)?
If they are compressed at the proper height then it sounds like they are too long, and I don't think the amount of rebound in the spring will change this.
Its a Serpent S411
Post a picture of what you are talking about.
Sounds like you are trying to set ride height with the droop screws? Adjust the shock collar for ride height.
you will have to adjust shock length and droop screw as well
Originally Posted by ekt
(Post 14009824)
I just put on RCM Super Short shocks,it fix everything
