WTF (Wild Turbo Fan) - OEM?
#107
Its pretty simple to test the effectiveness of any fan and duct work.
Run your car and take temperature readings.
I haven't created much of any duct work to speak of for any of my cars, however I have tested and tried about 5 or 6 different fans, ...the WTF's have brought my motor temps lower by about 7-10 degrees consistently and at least 5 degrees cooler than any other fan I've tried. I attribute that to the amount of air they are pushing.
#108
I'll be trying it at some point. but I've got a lot of things ahead of that.
Using the same fan, on my computers, I saw 20 degree reductions in core temperature by doing ductwork to stop reingestion of air. For an open fan, something like 30% the air that comes through it, is re-ingested air. And in this case, is pre-warmed.
#109
#113
On another note, Can anyone tell me what the square blue piece of plastic (might be clear plastic with blue protective film) that comes in the bag with the fan is for ?
#114
so.. I'm lead to believe that these fans are just relabels.
Wild Turbo Fan, RC Car Fan, RC Cooling Fan, Heat sink fan, RC car accessories, RC car, RC
That indicates it's the first fan that's not just a relabel. I think they're just running 5v fans at 8.4.
I was really hoping these were custom.
#116
I need to spend an evening with some lexan :-) Get a duct worked up so I can do some real testing.
#117
My newly acquired WTF 30mm fan will stop dead when in close proximity to certain parts of the 12T brushed motor in my Traxxas 4-Tec. At first I thought my fan was bad and ordered another one till I figured it out. lol Can't get too close to the motor! However, I've noticed that there are certain spots on the 12T motor that have much less of an affect on the fan. Perhaps this is the gap in between the magnets. For some reason, this doesn't seem to be a problem with my TSR brushless motor. Although I haven't tried moving the fan closer than 10mm or so or in different positions around the TSR motor. Fan works great on my TSR.
That piece of lexan is used to direct the airflow into the motor, like a simple shroud. Just use double sided tape and stick it on top of the fan.
#118
That's quite disappointing but makes sense after having 2 40mm fans completely die on me with no reason. I've only had TDX fans die on me after getting rocks stuck in them or having a bad crash and the fan coming off the sticky tape.
#120
Check on Amain.com because I just brought the connectors from them.
