PLEASE HELP
Old 05-01-2015, 11:53 AM
gmann's Avatar
Default PLEASE HELP
What spur gear and pinion gear should i use on 12.5 turn motor to make it fast?
gmann is offline
Old 05-01-2015, 12:13 PM
Cosmo's Avatar
As big of a pinion/small of a spur as you can without overheating it.
Beyond that, can't get any more specific unless you tell us what car, the length of the track, etc.
Cosmo is offline
Old 05-01-2015, 12:17 PM
Super Moderator
Kraig's Avatar
Trader Rating: 80 (100%+)
Do you have to run your car in zero timing (blinky) mode or can you run boost and turbo?
Kraig is offline
Old 05-01-2015, 12:20 PM
gmann's Avatar
Its a serpent s411,parking lot track,zero timing
gmann is offline
Old 05-01-2015, 12:32 PM
gmann's Avatar
Default Gear meshing
What is the correct way to mesh the gears?Thanks for helping
gmann is offline
