help motor newbie here >
Old 04-30-2015, 12:07 AM
cds13's Avatar
Angry help motor newbie here
hi all
new to electric raced nitro for years
i have just put my new car togther to our rules
i am running
tt01 chassis
tamiya 23 t BZ motor
durtrax de10 esc
2s lipo nano tech 4600mah
flysky 3ch receiver
digatal servo 1/8 scale
compleatly new to this
runnning motor with no load to make sure it works
but the motor goes like sh*t very slow and wires get warm after 2-3secs
help please
meant to race in 2 days :P
cds13 is offline
Old 04-30-2015, 12:32 AM
23T is a pretty slow motor to begin with. But if the motor is getting too hot too fast check for binding in the drive train. Without the motor in the car all the wheels should spin together fairly freely. Then when installing the motor make sure not to set the gear mesh too tight.
InspGadgt is offline
Old 04-30-2015, 12:46 AM
cds13's Avatar
oh ok i dont know if your meant to run a motor with no load but i have just to try it and it doesnt run right the wires get hot no load
thanks corey
cds13 is offline
Old 04-30-2015, 04:56 AM
Your not supposed to run brushless motors without a load.
With that being said it won't look like it's going very fast but you should be able to feel some torque.
2uzferunner03 is offline
Old 04-30-2015, 05:08 AM
oeoeo327's Avatar
Trader Rating: 75 (100%+)
Are you running a brushless ESC with a brushed motor? Your motor and ESC might be incompatible, or your wiring might be off. I'd check to make certain that the Duratrax ESC supports brushed motors.
oeoeo327 is offline
Old 04-30-2015, 06:46 AM
Sorry just realized your running a brushed system.
Check the brushes by removing the springs and popping them out. If their purple you burnt them up.
I would break in that motor...
Find a 6 cell nimh with about 1000mah on it or hook up a couple c sized batts together in series.
Drop the motor in a cup of water.
Hook the battery up directly to the motor and let it run until it's dead.
Spray it out with motor cleaner and re lube the bearings.
CAUTION. Don't get lube on the brushes.
This process breaks in the brushes to the armature commutators.
Old 04-30-2015, 07:54 AM
Geezatec's Avatar
23t motor considered a stock brushed motor, 28t to 21t are stock. 20t to 14t intermediate, 13t to 6t Pro's!!! lower the turns quicker they are. Same with brushless Higher KV stock motor and lower KV the quicker. Your Duratrak ESC capable of running brushless, I'd go brushless, with brushless you wont have to rebuild brushed motors. 4600mah batteries you will change to lipo's to 5000KV, + a lipo charger.
Upgrade the vehicle to now standards, Brushless!!! You'll be happier!!
good luck!!!
Geezatec is offline
Old 04-30-2015, 10:13 AM
good luck!!!
Sounds like the brushed motor is required for the class he's racing in. If not than I agree to go brushless.
Old 04-30-2015, 10:23 AM
BigBadDogg's Avatar
cds.. did you break brushed motor in ? also have you done esc radio setup ?..
if not do both .. I use a cup of antifreeze to break motor in with a single D cell. hookup drop in cup let it run..
I think ur esc is causing over heat due to not setup to radio..
sorry to hear all the confusion due to people not reading a post .. Best of luck
BigBadDogg is offline
Old 04-30-2015, 01:05 PM
cds13's Avatar
motor is broken in yes
i have to have a 23 t 540 brushed motor for my class
esc is designed to work with brushed or brushless half my club runs them
a radio setup ? sorry i dont know much about electric
cheers corey
cds13 is offline
Old 04-30-2015, 04:19 PM
Best thing is to just throw it on the track and see what it does. Since your racing in a club where everyone has the same equipment they would be able to help you more.
Old 05-01-2015, 01:11 AM
cds13's Avatar
i just ran the car for 10 secs i now have all the parts and now the esc smokes so its beyond me
cds13 is offline
Old 05-01-2015, 02:16 AM
Maybe a wiring error
From the manual:
CONNECTING BRUSHED MOTORS
There are two options for connecting brushed motors.
The motors can be connected as one-way (forward
only) or two-way (forward and reverse). When
using a brushed DC motor, please ensure that the
confi guration between the ESC and the motor must
be in accordance with the selected programming
in the ESC (forward or forward/reverse).
2 way: forward/reverse
orange yellow to - motor
bleu to + motor
1 way: Forward
orange yellow blue to - motor
+ from battery to + motor
stofke is offline
Old 05-01-2015, 07:24 AM
Jaymancd's Avatar
If it is smoking my guess is your esc is fried. I have had a few do the same thing. Look into another one or get in touch with the manufacturer.
Jaymancd is offline
Old 05-04-2015, 11:28 PM
gmann's Avatar
check the ESC to see if it can use lipos
gmann is offline
