Speed Passion SP-1 - 190mm track width (Ride tyres) >
Old 04-29-2015, 01:55 PM
Default Speed Passion SP-1 - 190mm track width (Ride tyres)
ting: 0
Hi all,
I have a brand new tresrey kit and plan to compete in the Formula class at ETS in Luxembourg. The problem I am having is achieving 190mm front track width with the new ride tyres.
The main issue is with the caster moulding, will the upgrade / option aluminium version solve this problem?
Has anyone else had this problem and how did you get around it?
Any help would be very much appreciated.
lee150978 is offline
Old 04-29-2015, 03:25 PM
Trader Rating: 17 (100%+)
Originally Posted by lee150978 View Post
ting: 0
Hi all,
You DO NOT need any option in order to get the front track width to within 190mm...you just need to use the most inner mounting point (check your manual carefully) and you should get to 188 189mm or exactly 190mm with Ride Tires.
One of the problem is RIDE wheel are using wide offset (very well known of this wheel)....when we are using Pit or Tamiya style wheel, the track width are always within the 190mm....
Last year Thomas Plumper is using our SP1 with Ride wheel racing at ETS without any problem.....not unless this year RIDE tires are even wider then it should be.
Solara is offline
Old 04-30-2015, 12:56 AM
Hi,
Thanks for your response.
I have tried the inner most setting but the plastic caster plate mounting holes are then too wide to match up with the wishbone mounts.
I wasn't sure if I needed to re-drill the caster plate or purchase the aluminium option part as this has additional holes.
I will FB message Thomas Pumpler and ask his advice.
Darren
Old 04-30-2015, 01:41 AM
Hi,
I cant find any way of contacting Thomas about how he achieved the correct track width.
Can anyone else help please?
Old 04-30-2015, 02:53 AM
Jorge T's Avatar
Trader Rating: 14 (100%+)
Hi,
Darren
Either re-drill the caster plate or get the aluminum plate that has both holes already drilled.
Jorge T is offline
